Home > For Sale & Wanted > SOLD Bbus and extension lead. Less than a year old.
Defender marto
United Kingdom 2004 Defender 90 Td5 HT Oslo Blue
I have for sale the bbus and an extension lead with the proper plugs so no splicing of wires needed. I could not get this working on my td5 and I quickly gave up after neighbours complaining and giving myself whistling noises in my ears. So took it off in frustration and been in the box ever since. The Landy is now sold so it needs a new home. I am asking £150 ono inc postage. Marto
Post #637777 16th Jul 2017 11:27am
Gutch1985
Is this the front one on the new pumas with the battery built in it
Post #637868 16th Jul 2017 9:07pm
Defender marto
Yes that is tight it is placed at the front with built in battery.
Post #637870 16th Jul 2017 9:10pm
Defender marto
A bump before it goes on the bay
Post #638512 19th Jul 2017 9:00pm
Harry.O
Is the lead supplied part of a genuine loom or is it one of the relocation versions that allows you to move the BBUS?
Post #638763 21st Jul 2017 11:01am
Bomber82
Italy 2009 Defender 110 Puma 2.4 SW Zermatt Silver
Sorry for my ignorance but what does it is makes for?? Matteo
Defender 110 Td4 SE MY 09
Post #638962 22nd Jul 2017 9:34am
Defender marto
It is a relocation lead so you can move it to a more secure location.
Post #638985 22nd Jul 2017 1:04pm
Defender marto
Mi dispiace, non sono sicuro di cosa intendi.
Parlo spagnolo se questo aiuta.
Post #638986 22nd Jul 2017 1:08pm
proloForêt
France 2008 Defender 90 Puma 2.4 XS CSW Java Black
My 2007 90 SW xs does not have this behind it headlight. I am curious if usually it was optional specification. ]
My defender is UK car so I believe should have this.
If I can confirm this is the case and I should have this and can fit it with ease because of compatability, I would be interested to take.
Post #638989 22nd Jul 2017 1:35pm
Defender marto
If i am right there may or may not be a plug there as the puma Landy did not always have them as I think it was an optional extra. But on the td5 models the plug always seems to be there. Marto
Post #638991 22nd Jul 2017 1:39pm
proloForêt
Do you know would the plug be behind the headlight also or in a different place (the cable in picture look long)?
I am looking and can noot see any place to attach cable obviously. My puma have alarm though and my reading suggest this is extension to that.
Post #638997 22nd Jul 2017 2:37pm
Defender marto
Hi. The cable you see in the picture is an extension cable so you can move the bbus away from the front of the car. If you have the cable it will be probably just hanging below the headlight. If you have the normal horn alarm the plug you want is on the same loom as the plug going to your normal alarm.
Plug you are looking for looks like this but in brown.
Post #638998 22nd Jul 2017 2:54pm
DAZ110
Did you originally buy this from Matt at FCX?
Post #639002 22nd Jul 2017 3:36pm
Defender marto
No. I got it from island 4x4.
Post #639003 22nd Jul 2017 3:51pm
The TD5 wing harness had the BBUS connector as standard but the TDCi only has it if a BBUS was factory fitted. You would need to obtain a suitable harness to retrofit this to a TDCi but it is a straightforward job.
Post #639096 23rd Jul 2017 8:37am
