Home > Puma (Tdci) > Dual Finish Alloys and spacers? |
You're right, they're no different than Boosts Darren
12th Jul 2017 2:05pm |
From what i've seen of them they look like the Boost casting/Forging with some extra machining done on the outer faces.
12th Jul 2017 2:09pm |
CarlinAbz Member Since: 15 Sep 2013 Location: Aberdeenshire Posts: 76 |
Click image to enlarge Dual finish alloys with spacers and 265 tyres. Hope this helps. |
12th Jul 2017 3:07pm |
Rallymental Member Since: 17 Aug 2015 Location: The Garden of England Posts: 468 |
Thanks!
What spacers did you use? The definition of insanity is doing the same thing over and over again but expecting different results. Solihull, 1948 - "If we paint the chassis, it will last for years" Solihull, 2015 - "If we paint the chassis............................. |
12th Jul 2017 3:39pm |
They are 30mm spacers, I think they were from Terrafirma but it was over three years ago that they were fitted so I might be wrong. The alloys need refurbished now as they have not survived the last 3 Aberdeen winters very well so I have been thinking swapping them out for 18s from Twisted with 285 AT3s. The sensible option is £65 per wheel refurb and keep the current set up.
12th Jul 2017 4:41pm |
Click image to enlarge This photo better shows the fit in the arches, tyre just inside the wheel arch and has passed the MOT with this set up. |
12th Jul 2017 4:48pm |
Thanks for the last photo, I was a bit concerned that the tyres would sit outside the arches.
The terrafirma ones seem to be the best value at around £120 for 4 with the nuts. The definition of insanity is doing the same thing over and over again but expecting different results. Solihull, 1948 - "If we paint the chassis, it will last for years" Solihull, 2015 - "If we paint the chassis............................. |
13th Jul 2017 9:38am |
