Home > Spotted > Old and New ! Spot the difference
foxyred
England 1994 Defender 90 200 Tdi HT Montalcino Red
Spotted on local Clay Pidgeon Shoot
One of the last defenders and one of the last 90's !
But you will have to look to see which is which
Post #636950 11th Jul 2017 3:20pm
It's not that tricky - the one on the right has vent flaps and the wrong bonnet. Darren
Post #636951 11th Jul 2017 3:22pm
ickle
As above
Also the one on the right is now probably better made with the care and attention sadly lacking from the production line.....
Post #636957 11th Jul 2017 4:06pm
Caterham
I was going to say the one on the right is the Puma - famous for failed park switch on the wiper motor.....
Rolling with laughter
Post #636959 11th Jul 2017 4:31pm
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
Ribbed roof on the 90.
Post #636965 11th Jul 2017 5:39pm
foxyred
Both have ribbed roof's, both pickups one has an ifor Williams back on
Post #636978 11th Jul 2017 7:02pm
keith
Inch higher on the oldie
Post #636985 11th Jul 2017 7:30pm
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
One on the right is an older one, a 300 I reckon by the look of the intercooler and radiator set up. as well as the bulkhead flaps.
Can't see the dash on it either, the puma clocks binnacle and top blower vents are just about visible on the one on the left
Post #637037 11th Jul 2017 9:30pm
RoddyK05
No doubt the older vehicle is on the right, but it says one of the last 90s so it can't be a 300 as the 90 was pre defender.
Post #637051 11th Jul 2017 9:58pm
BuckBlu110
Transplant maybe? Can't imagine someone has gone through such a restoration and left the old 2.5 turbo in it though?! Shocked
Might well be a 200, think they where the same, though Cant quite remember the 200 rad/intercooler set up, but sure looks like the same layout as the 300 with the little intercooler to the side of the radiator.
Post #637054 11th Jul 2017 10:05pm
JR
Scotland 1984 Defender 90 200 Tdi SW Coniston Green
BuckBlu110: The genuine 200 set up behind the grille is the same though the part nos. are different I believe due to the different plumbing layout under the bonnet.
It cannot be a factory fit 200 if it is one of the last 90's as the 200 fitment came alongside the change to Defender. As said above, it should have been a TD at the tail end, unless it was a contract build. I have a '93 K Defender 90 here which had a 2.5 NAS and was built to a Royal Mail contract.
Post #637135 12th Jul 2017 1:33pm
ericvv
If the newer one really is one of the last Defenders produced, then someone removed the Defender bonnet letters and replaced them by the Land Rover bonnet letters used until about 2012 or so. Not many people doing that.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #637150 12th Jul 2017 2:33pm
foxyred
The one on the right is a 1990 G
Had a unrepairable chassis, and a locked solid 2.5TD engine.
Has been fully rebuilt from a new Richards chassis, very low mileage 200tdi engine, rebuilt g/box and transfer box, rear fuel tank and new interior and all new exterior panels
Post #637382 13th Jul 2017 7:53pm
