![]() | Home > Land Rover Customer Relations > Q421 Oil Pump Failure |
Dobby Member Since: 23 May 2012 Location: East Seaxe Posts: 187 ![]() |
Same story here. 2012 with VIN in the range. 2 local dealers tell me the work doesn't need to be done, but I'm convinced that's because the campaign is no longer live on TOPIx or the dealer system.
Can't get a solid answer from anyone if the work is actually needed or not. CRC@Landrover told me it would be out of my own pocket though. Does anyone know if there is a way to inspect the vehicle to see if the work has been completed? Any visual clues? I'm guessing not, as it's all internal. Cheers Dobby |
Has your engine been remover ? as you need to remove sump to replace oil pump
Not that I can tell. It's been regularly waxoiled, so everything looks the same under there.
