Home > In Car Electronics > Alpine CDE-133BT - new aerial needed
stuart123
United Kingdom 2009 Defender 90 Puma 2.4 CSW Aintree Green
Have searched without success already... Sad
The above is described as having "Power Antenna Output".
Does this mean there is an option of adding an amplified aerial to it? Or would I just have to buy an amplified aerial and then take power from somewhere else?
thanks
Stuart
Post #635337 3rd Jul 2017 2:56pm
mk1collector
The power antenna output is for an electric aerial, as in the aerial goes up when the stereo is switched on and down when the stereo is switched off. Ray
My build thread
Post #635340 3rd Jul 2017 3:19pm
^^^^ This, it should be 'capped' and not connected. KEEP CALM AND Drill ON
Post #635345 3rd Jul 2017 3:39pm
stuart123
Capped and not connected?! How do you mean?
Sorry...
Post #635348 3rd Jul 2017 3:43pm
Protected from shorting on any bodywork. So no bare end it should either have a little adhesive heatshrink on the end or electrical tape to insulate it. KEEP CALM AND Drill ON
Post #635355 3rd Jul 2017 5:01pm
