![]() | Home > Td5 > Td5 fuel regulator help |
sgilmour Member Since: 21 Jul 2015 Location: Essex Posts: 232 ![]() ![]() ![]() |
Evening all, start off with an apology as this is a Disco Td5 not a Defender
![]() I had to get recovered from the motorway yesterday after a diesel leak and upon inspection the fuel regulator pipe from the head black to the regulator boss has backed out under pressure. (Picture probably helps more!) ![]() Click image to enlarge I tightened up the brass fitting and it sorted the leak but backed out and leaked after a short test run. Anyone had this before? And what would people recommend as a fix, loctite and cross fingers? Cheers! Stuart 1994 Defender 90 300TDi 2002 Disco II ES Td5 Auto (SOLD) 2011 BMW 120d M Sport 2012 Audi A5 Coupe 2.0 TDI (Other halfs) |
