Home > Tdi > Running 300tdi with no power steering fluid?
trickster5000
United Kingdom 1989 Defender 90 300 Tdi CSW Arles Blue
The union nut for the power steering high pressure pipe was seized on so I ended up snapping the pipe to get it off when I took the engine out. I now have the new engine in and a new pipe on order but it won't arrive until wed/thurs.
I was wondering if I should wait until the new pipe arrives to try starting up the engine (will it cause any damage to the pump?) or if it would be ok to run it without fluid? (I'm really desperate to find out if this new engine runs!)
TIA, Matt. Matt.
'89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html
Post #634715 30th Jun 2017 4:37pm
grafty99
Could you use a bit of garden hose or something as a temporary solution so you can run it up?
Running the pump dry isn't going to do it any favours 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #634735 30th Jun 2017 6:20pm
trickster5000
I thought of that but I didn't think I would be able to attach it strongly enough for the high pressure without damaging the thread.
I think I'll just wait until the proper pipe arrives.
Thanks anyway. Matt.
Post #634751 30th Jun 2017 6:49pm
Mdm
When you start it oil will go every where if it has any in and if to empty you will get serious dange quite quickly
Post #634760 30th Jun 2017 7:07pm
