Home > Technical > Rear ABS sensor
Lrd300
Malta 2004 Defender 90 Td5 ST Barolo Black
Rear ABS sensor
I need to replace the rear disc brake of my 2004 Defender 110 (P38 axle) which has ABS
Is the discs different from non ABS ones? Does it have some toothed ring at the back for the ABS pickup sensor?
Thanks
Post #634635 30th Jun 2017 12:15pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
Discs are the same, there are holes in the discs to bolt the abs exciter ring.
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #634643 30th Jun 2017 12:29pm
