![]() | Home > My Defender > 1986 110 station wagon project |
I think the side repeaters were spec dependant rather than age in the early days. There are lots of pictures of earlier vehicles with them fitted. Darren
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5230 ![]() ![]() |
is it me or do they look better with out the repeater in the wing? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
It's just you
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1629 ![]() ![]() ![]() |
My October 85 has the side repeaters. I tend to like the wings without them personally.
Gas man Member Since: 29 Jun 2017 Location: East Yorkshire Posts: 33 ![]() ![]() ![]() |
A turn of events...
Having bought a new half chassis for this I found an unused complete galvanised chassis from failed project with 200tdi mounts at the right money, so seemed like a good idea. So, anyone want a half chassis, or I might repair the old chassis as planned to have a good non galv chassis (with front leg replaced) for another project. With the new chassis I plan to paint it with direct to galv paint and waxoyl inside. One problem I've found is that the fuel tank mounting has a cradle for the later plastic one, but I have a new metal one - does anyone know if this can still be used? |
New chassis all painted up now
Td5 tank with 300tdi discovery sender unit in the tank seems to fit. I haven’t got a locking ring for this yet, so probably a good idea anyway to refit the discovery fuel tank access plate in the rear tub floor. The only problem I see is steel versus aluminium, but it will be painted etc Dismantling of the “old defender”, rear tub resting on a box and I’ll lift the roof and rear side windows off in one go. ![]() Click image to enlarge |
Looking good and making progress!
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Strip down continues, didn’t take long for front end strip down and engine out, so hopefully soon actual rebuilding on the new chassis.
Decided to strip bonnet and galvanise the frame, although the bonding glue is quite tough to saw through. Although it’s not the standard look, the rrar tub capping are off the be galvanised, except the corner ones which unfortunately I think are too rust pitted to reuse. ![]() Click image to enlarge |
Slow progress, but at least it’s building rather than dismantling!
