![]() | Home > Puma (Tdci) > Brake failure. |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5087 ![]() ![]() ![]() |
Ive not but its worth i think checking.
At least it was when it was and your all safe Mike |
dullbird Member Since: 25 Aug 2007 Location: sydney Posts: 87 ![]() ![]() ![]() |
i believe this happened to someone in oz on there trip around...the heat sheild had cracked apparently not uncommon in the defender and then this came off cutting through the abs. YOU KNOW REHAB IS FOR QUITTERS!!!!
Tony_Hillerby Member Since: 03 Feb 2008 Location: Inverurie Posts: 36 ![]() ![]() ![]() |
These are the pictures of where the brake pipe has gone through at the back of the heat shield.
Tony ![]() ![]() |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2110 ![]() ![]() ![]() |
We had something similar but was the vacuum pump broken (according to the dealer)...
If I remember well there is a special Bulleting regarding that in the GTR database. Regards Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 ![]() ![]() ![]() |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
Though it was you Andrew, that had a similar problem,, ,
See you beat me to it,, finding you previous thread ![]() Mine check again, and still OK !!! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
I checked - mixed bag, one pipe not in the clip running up to the bulkhead clip lost its clipieness.
Cabletied that to the bracket - luckily not touching the heat shield. Also put a loose tie round the other clip. One question, i placed a thin cable tie round one of the pipes as despite them all being in and in their clips it was touching the other break pipe and that didnt seem good, so ive at least put some platic between them - any comments? Mike |
