Home > Camping, Caravanning and Holidays > Defender and towing a caravan what towbar?
Page 1 of 3 123>
Stacey007
Hello
I've had to move a caravan from my late father in law to our house to clean and sell it...
What a phaff... the spare wheel was in the way of the stabzliaer handle, so had to take it off (one cap would not move) tried with door open but door would not shut past handbrake when down if I tried that way.
Then it sat too high....even on the lowest setting? anyway left it late and cruised back so home with it lucky quite close.
What do people do that have a caravans as we could be looking at a new one as some point.
Do I need a longer drop plate? I'm thinking take the original tow bar off and then get a longer drop plate? which should get much lower?
I've had no issue with the sankey of tip trailer its the stabilizer handle that has to be up before you locate on towball.
Post #632009 17th Jun 2017 9:59pm
You've got a bit of a Censored set up there, with a Dixon Bate ladder bolted to a standard fixed tow bar, so it's no wonder the caravan wouldn't hitch properly.
You need a standard Dixon Bate set up, which will allow you to position the slider lower down for a 'van, which will in turn enable you to operate the hitch stabiliser. Like this:
 Darren
Post #632014 17th Jun 2017 10:24pm
You've got 2 types of tow bars fitted! There must be a trophy for that, because it's the first I've seen !
As anorak says Thumbs Up
Post #632034 18th Jun 2017 5:52am
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
As all above - just fit standard Dixon Bate setup. I still have to remove my spare - I have an extra spare wheel carrrier bolted to my roof rack. The spare goes up there at the start of the season and comes back down at the end of the season.
Post #632036 18th Jun 2017 6:27am
DuncanS
United Kingdom 2008 Defender 110 Puma 2.4 USW Santorini Black
There is a different type of handle available for the Alko hitch IIRC.
Here, found it: http://www.al-ko.co.uk/edit/files/handbooks/4x4lr.pdf
http://www.defender2.net/forum/post436065.html North Cumbria Search and Rescue - Team Leader
Post #632044 18th Jun 2017 7:13am
ARC99
I can see what you were trying to do but that is very dangerous you have the nose up.
It would have been a lot simpler if you had taken your dirty ball off and used the clean one that is fitted to the ladder or even easier clean the ball that you have fitted that way the caravan would have nose would have been lower. Don't make old people mad.
Richard
Post #632063 18th Jun 2017 10:04am
Sammyboy
United Kingdom 2012 Defender 110 Puma 2.2 USW Sumatra Black
Agree with ARC99. Remove your DB assembly and use your lower ball, just make sure you degrease it before attaching caravan. When hitched up your caravan should be at least level but preferrably slightly nose down to improve its stability when travelling. Good luck. Discovery 4 HSE
Defender 2.2 110 USW XS
Ford Kuga AWD
Discovery 3
Range Rover P38
Discovery - 300 TDI
Discovery - 200TDI
Post #632118 18th Jun 2017 7:26pm
Stacey007
Thanks all,
I know it was a botch job but trying to help out and my mother in law wanted the van gone...
Even with the dixon bate drop plate you still have to take the wheel off? what a phaff... Also putting it back on was hard !!
On the setup you showed anorak, I still think the handle for the stabilizer would hit?
The different handle looks good but this van isn't a keeper just cleaned it and it will be up fro sale however worth noting if we get one.
Is this what I need ? rather than change mine for a longer slider as above?
http://www.ebay.co.uk/itm/Land-Rover-Defen...Track=true
Post #632127 18th Jun 2017 7:56pm
I never had to remove the spare or alter the handle on my van when using the standard setup shown. Darren
Post #632172 19th Jun 2017 5:26am
ARC99
I have never trusted the Alko hitch with built in stabiliser I prefer the old fashioned type . I have a Shocklink which fits the ladder and have in the past used a 2" spacer between the Shocklink and the tow ball to make it easier to hitch up. Don't make old people mad.
Richard
Post #632191 19th Jun 2017 8:53am
Why's that, just out of interest? I'd have thought that the Alko hitch fell into the 'tried and tested' category after all these years? Darren
Post #632197 19th Jun 2017 9:25am
ARC99
I have experienced two failures of this type of hitch which was the earlier version, both times the pads just disintegrated which is not a good thing while traveling at 60 mph on the motor way, all you can feel is the van trying to move sideways on the ball due to the increased clearance. The first time I spent 10 hours sat in a services waiting for the nearest caravan dealers to open to purchase a replacement set of pads then returning and having the joy of having to fit them. After the second time scraped the hitch and bought a new old style hitch and stabiliser. Even when purchasing new caravans which I have done frequently of the last 30 years I have swapped out that type of hitch for the old style. Don't make old people mad.
Richard
Post #632200 19th Jun 2017 9:43am
Devon-Rover
United Kingdom 2014 Defender 110 Puma 2.2 USW Aintree Green
I have the traditional DB ladder and the alko handle doesn't hit the spare when I have had a caravan with one fitted on the back.
On the bottom pin the top of the ball is just a fraction over 11 inches from the bottom of the spare.
Post #632238 19th Jun 2017 1:08pm
Stacey007
Thanks all,
Can you also add a spacer to these for the towbar?
My wife really wasn't keen on these pin type setups but as I explained it's pretty much the norm with defenders..
Post #632242 19th Jun 2017 1:14pm
X4SKP
Hello Stacey007
Dixon Bate 200mm Adjustable Drop Plate fitted to a NAS Rear Step / Tow Frame
(NAS Rear Step Lowers the fixing positions for Tow Frames by around 85mm)
Bottom Slider Bolted through (so Locked into position / No Rattle)
Custom additional Metalwork to brace lower aspect
Enough room for a Second Slider to position a NATO Hitch (For Trailer)
Older Style ALKO Hitch on Caravan (with stabilizer pads) Rotating Lock Mechanism
to engage / release (No conflict with Spare Tyre)
Good Luck... SKIP
Post #632258 19th Jun 2017 1:55pm
Page 1 of 3 123>
