Home > Puma (Tdci) > Switch fascia |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 |
I'll be wiring in spotlights in a week's time and wanted to replace the blank facia of one of the dash switches with one from a front fog or driving light (already got the switch mechanism from my old Disco).
Does anyone know if this is available as a separate part or the part number of the whole switch? I'm going to try a few second hand parts dealers as I think I'm right in saying this was the same on the Td5??? If all else fails I'll get creative with the Dremel and some white paint. 110 2.4TDCi 110 300Tdi LROCV ::: AULRO.com Last edited by dm_td5 on 27th Sep 2008 7:52am. Edited 1 time in total |
26th Sep 2008 1:10pm |
chalky Member Since: 09 May 2008 Location: Yorkshire Posts: 483 |
I think its the same as th TD5 !
I too am looking for a switch and wiring loom ! there are some original wiring kits from LR to replace the WARN one made by PIAA if some one PMs me i will send them pics to post ! The wiring comes with switch relays and everything else ! DEFENDER XS CSW 08 TONGA GREEN |
26th Sep 2008 3:47pm |
I have the switch as it is also the same unit as a Disco2 binnacle switch, just a different fascia. The switch I have is an old D2 cruise control and so is a latching type with a ON indication lamp. I'm hoping to get a fascia with the light symbol and number 2.
In Australia the spotlights must by law be wired so they can only come on if high (main) beam is also on. This means a relayed circuit with a trigger off the high beam is the easiest way to provide power to the switch. 110 2.4TDCi 110 300Tdi LROCV ::: AULRO.com |
26th Sep 2008 9:21pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5035 |
I did a lot with these switches a while ago and as it happens there are some on my desk!
The blank i have i would like to put in an aux 2 light switch and i bet they make one. The problem them comes with the rear connectors - what i did a while ago was take them of a breaking car - but you can also use tiny crimps. When interchanging the fronts i broke the clips often so be careful - what i would say is the normal fog light switch is latching so one of those and your away Mike |
27th Sep 2008 7:06am |
Yep, tiny crimps is what I used too. The switch parts the easy bit being the same piece as the Disco. Like you say careful changing the face plate though.
They do make an Aux 2 light switch and this is the fascia I'm trying to get. I believe it is only available as part of the Aux wiring kit though and not as a stand alone part 110 2.4TDCi 110 300Tdi LROCV ::: AULRO.com |
27th Sep 2008 7:52am |
dave's 110 Member Since: 11 Jun 2008 Location: Norfolk Posts: 45 |
I have found the best switch to use is the heated rear window from td5 or 2007 on wards, as it's a push on push off switch to get the right face plate you need to order the light switch 2 these will not work with out wiring through a ECU so I just unclip the face plate and swap with heated rear window one and as only 3.50 each it's not a lot of money to have the right looking switch's in your dash
See my photo's would add them here if I could find out how to http://www.saharanomads.com/gallery/showphoto.php?photo=63 http://www.saharanomads.com/gallery/showphoto.php?photo=66 To get back light and little red light on is not that hard only thing is the switch don't come with a plug but you can use some small female spade Dave P.S if any one wants part number for the both switch I can find that out as can't find them right know in my tip of an office as you can buy these switch's on there own. |
27th Sep 2008 6:38pm |
Dave, that is exactly the switch I am after. As said I already, I have the latching type switch assemble to put behind it, this also has the light built in. So yes please either post up or PM me the part number of the switch.
In your gallery pic's you show the wiring to the instrument cluster, was this to tap in to the main beam wire ? Can you recall if what colour(s) it was? Buy the switch, swap the fascia, wire in spotlights ... bingo 110 2.4TDCi 110 300Tdi LROCV ::: AULRO.com |
27th Sep 2008 9:15pm |
I to would be interested in the switch front part no. and the best switch to provide the light
Was it a matter of removing the stereo and being able to reach the switch recess? Mike |
27th Sep 2008 9:52pm |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2109 |
mse
According to the workshop manual you only need to remove the stereo to hav acces to the back of the switchs. If you like I have the dismount procedure. Regards Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
28th Sep 2008 12:07am |
What I will do is check and see what way round you have to wire up switch's back light is red/orange earth black then live in and live out when wire up right, the little red light show when switch is on . You can't just get the switch front for Aux 2 light switch you have to buy the switch and swap front face of switch they flick off easy. So you buy 2 switch's and make one out of the 2 to get a push/on push/off Aux 2 light switch This is where I took the feed for light's http://www.saharanomads.com/gallery/showphoto.php?photo=64 If you want better pic PM me with your email and I will send them to you as in my Gallery pic are smaller then on my pc Hope this is of help to you All Dave |
28th Sep 2008 8:30am |
28th Sep 2008 8:42am |
Yes please Yes you do have to buy several switches and break them up - i have a box of disco ones for another project. The disco aux 2 fronts are for around the speedo - so i would be interested in the parts for the defender version. Its also which is best as a latching (push on and hold) switch to use there are a few Mike |
28th Sep 2008 9:21am |
From the Disco switches the only one that is latching it the Cruise Control. It has the advantage of also having the light in it.
Still coming to terms with the Puma but the switches are the same sleeve part as the Disco. Any of those that are latching would be OK - A/C, Rear Fog, Rear Wiper. My preference would be rear fog or A/C as they have lights in them, like the Disco Cruise Control. 110 2.4TDCi 110 300Tdi LROCV ::: AULRO.com |
28th Sep 2008 9:50am |
Sorry penny dropped should have said - Rang Rover Classic Switches are latching and there are loads of square ones with lights in. Disco 2 switches i didnt think of cruise i think hazards is latching heated front and rear are momentary i assume HDC is the same. Mike
28th Sep 2008 10:56am |
