Home > In Car Electronics > Advice needed - DRL/spotlight wiring
acnorman1
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Corris Grey
Currently have DRLs running on an ignition feed which then switch off when the sidelights come on. I also have some IPF spots on the A-bar which are on a separate switch and only come on with the full beam. What I am trying to do is wire in another relay so that the DRLs switch back on when the spotlights are on. Essentially I need to find a way to interrupt the feed from the sidelights when the spots are switched on.
Any advice on where to tap in and wire a changeover relay? I have got as far as needing to wire the sidelight feed to the DRL through 30/87a but where to pick up the 85/86 feed?!
All help/suggestions would be appreciated!
Thanks
Post #632001 17th Jun 2017 9:03pm
