![]() | Home > Puma (Tdci) > Injector Seals |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
Yeah, it looked like that all right
Just get this kit.
http://www.ebay.co.uk/itm/O-E-FORD-FUEL-IN...Swal5YHIYe The small O-rings are for the fuel return line on the tops of the injectors (i personaly didn't find them to be needed). You have the copper washer which seals the injector into the combustion chamber and then rubber oil seals for the cam cover. DO NOT buy the copper washers from Land Rover, they charge around £18 each, it's a total rip off for them. If you really insist on buying genuine, then buy some from a Citroen dealer for a 2.2 Citroen Relay (they use the Puma engine too), they're around £7 each, or Ford charge about £8.50 each. You can usually get them for about £1 each from your local diesel injection specialist. They're actually nothing unique, they're matched to the injectors rather than the engine. |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 756 ![]() ![]() ![]() |
Thanks for the tip, zsd-puma!
This will help. |
