Home > Puma (Tdci) > Puma 2007 fuel cooler pipes
richb1965
France 2007 Defender 110 Puma 2.4 XS CSW Zermatt Silver
Hi to everyone.
I'm a new member and have had my puma from new so it's just turned 10 years old.
A quick question please, I'm embarking on a full service with a coolant change. I know where the fuel cooler is and can see the pipes that I must disconnect. Is there a special technique ie how do I undo them? Is it a press and pull on the coupling, special tool or something else. I just don't want to damage or break them in the process. I also know that the thermostat housing pipe is a PITA? Sad
Any tips or advice would be fabulous.
Many Thanks in advance.
Richard
Post #631316 14th Jun 2017 12:51pm
MK
No special tools required. Just make sure you press the clips evenly and move in and out. You may need to pressure (lightly) wash the connections as they get with grit. Puma 110" SW
Post #631326 14th Jun 2017 1:15pm
The thermostat housing pipe is less of s pain imo. That what I opted for TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #631331 14th Jun 2017 1:32pm
richb1965
Thanks guys, much appreciated Razz
Post #631409 14th Jun 2017 7:40pm
