![]() | Home > Td5 > Disaster |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5813 ![]() ![]() |
Is there a core plug/bolt thing that sticks out at the front of the head, exhaust manifold side??????????
Just after I brought mine it leaked along the exhaust manifold, and was an easy fix, warranty Andy |
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 587 ![]() ![]() ![]() |
OK, thanks Andy. I will definitely be diagnosing this 100% befor removing and replacing the head. Will look into that.
Just thinking though is that it has been sat still for about 5 days. Forgot to add it is a year 2000 with 100k on. Steve |
Should be ok then,
Mines an 04 with 135thou ![]() ![]() Andy |
Here is a pic and it shows a core plug thing on the side of the head, and this one has also been leaking
Also check the top hose fitting, had a mates one where the hose clip had corroded through http://img713.imageshack.us/img713/636/oil...eturnp.jpg Andy |
Thanks again. I guess all will become clear once the manifold is off. I have some nice stainless steel hose clips in the garage
Good luck with it
![]() ![]() Andy |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17610 ![]() ![]() ![]() |
This is a well-known leak hot spot on the TD5 - my Disco 2 has been weeping slightly from here for 5 years and 100k miles and all I have done is top up the coolant once a month or so. It's on the list of jobs to get round to when time permits, and has been for 5 years! If the leak is not too bad, I wouldn't worry overmuch about it. Really useful photo by the way, thanks Andy! |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 ![]() ![]() |
Turner Engineering put on stronger heads which are imported from Spain onto their remanufactured TD5 engines. Cracked heads are especially common on re-mapped engines apparently! Should be able to buy one from them
I waited til the end of the month and as my tax has run out and have sorn until April.
Took a few bits off yesterday and Landy Andy was spot on ![]() Going out now (in the rain) to remove the head, I want to check the dowels and also 3 exhaust studs were already broken. The plan there is to helicoil the exhaust stud holes and fit long bolts and spacers, also drill out the outer stud holes in the manifold. Skim the manifold but not remove the webbing. I may also give the cooling system a complete overhaul, new radiator/w-pump and maybe new pipes. The top hose adapter on the head is also showing signs of corrosion. Maybe some photos later. Steve |
BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785 ![]() ![]() ![]() |
I had the gasket go in my disco 2 and the garage was talking about the new reinforced heads from Spain. They are the same people that reinforced the v8 Heads. Russell 2011MY 110 XS USW Black |
MONKEYCOPPER Member Since: 26 Feb 2011 Location: Gloucestershire Posts: 4 ![]() ![]() ![]() |
i can beat that with mine, 04, 146,000 ! ! ![]() |
100k on my year 2000, I guess it woul have gone for much longer if I wasn't determined to find the water leak.
Anyone else have to top up there water? I was putting about 200ml every other month Steve |
changill Member Since: 13 Dec 2008 Location: North West - Preston/Lancaster Posts: 27 ![]() ![]() ![]() |
Not yet Steve.....but wife's mate is putting a similar amount in her Disco 2. I'll have a look at the core plug next time I'm round her house. ![]() Nanocom Available in the North West |
Yup, like I said earlier in the thread, I have been adding a teacupful a month for the last five years or so to my Disco 2. It's an '02 with 200k miles, by the way, so I win! ![]() |
