Home > Puma (Tdci) > A Frame Bushes
noworries4x4
A Frame Bushes
Just done a search on here re the above as my rear end has all gone wobbly Shocked scarry actually as mine is set up with heavy anti rollbar. I popped my head under last night with a pry bar and the drag links seem fine anti rollbar a little worm but nothing to bad, i never got right under as it was propped on a forklift at work.
Question ?? After reading on here they have changed the mounts to welded ones how do you change the bushes now, i used to just unbolt the lot off the crossmember.
Also whats the best bush to put back in (heavy heavy duty) towing every day
Thanks If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle
Weekends 07MY L322 TDV8 Vogue SE
No Worries 4X4
Post #58360 10th Feb 2011 8:40pm
MK
So yours have the welded bracket. You should just take the bolt and nut off and drop both arms. I think superpro bushes have 3 years warranty. Puma 110" SW
Post #58385 10th Feb 2011 10:00pm
