![]() | Home > Off Topic > Which torque wrench. |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1776 ![]() ![]() ![]() |
Teng tools do a couple of versions of their 1/2" torque wrench that should cover you.
Having said that I've never needed one that goes past 150lbft or so! |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 723 ![]() ![]() ![]() |
I've had a 1/2 inch Teng for quite a few years, from memory it does 45-200nm and has an angular gauge on the head which is handy for incremental fixings such as cylinder head bolts.
More recently I bought a 3/8 Norbar and the quality is very good, they are a little more expensive though. |
I've got one of these Halfords Pro ones. They're actually UK made Norbar torque wrenches with halfords branding.
(The calibration certificate they come with is Norbar.) http://www.halfords.com/workshop-tools/too...h-60-300nm They're fully serviceable by Norbar. |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2539 ![]() ![]() ![]() |
I've had a Britool EVT torque wrench for at least 20 years and it has given excellent service. I've also had experience of Norbar products which are also excellent quality. I wouldn't hesitate recommending either brand. Defender 90XS SW
apt100 Member Since: 05 Mar 2015 Location: Derbyshire Posts: 1547 ![]() ![]() ![]() |
I've also got the Halfords (Norbar) and would buy again. (It is also marked in ft.lb as well as Nm)
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 ![]() ![]() |
Warren and brown 2% calibrated accuracy 👍
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5941 ![]() ![]() ![]() |
Over time I have bought three of them of various ranges, Machine mart, Stag tools (Motorworld) and a Halfords one.
Would certainly by a Halfords again (even more so, now I have trade card) 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Trundlebus Member Since: 15 Jul 2014 Location: Herts Posts: 99 ![]() ![]() |
Hooray, at last someone who does not mangle english by saying "what torque wrench"
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17729 ![]() ![]() ![]() |
Most of my torque wrenches are Britool, but from the good old days before Britool relaunched into the budget sector of the market. I don't know if Britool torque wrenches have gone the same way as all the rest of their tools, but I hope not.
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2303 ![]() ![]() ![]() |
Hello ChrisCM
Your logic is sound, and it's worth getting a Torgue Wrench to tackle these jobs with high settings like this, but just a couple of observations for the Wheel Hub Nuts. For Hub Nuts / Wheel Bearing using Internal Spacers 1. It is really worth getting a good quality 52mm Socket so that the force needed to 'break' this undone is transmitted 'optimally' into the Hub Nut ![]() Click image to enlarge 2. The Bearings use a Spacer between the opposing races that prevents...in general terms over tightening If you have a Torgue Wrench that will go this high then fine but if not, tightening these to the 'technical setting' of 'FT' will be fine... ![]() ![]() Click image to enlarge Good Luck SKIP https://www.defender2.net/forum/topic83242.html |
You could, of course, get a torque multiplier and use your existing torque wrench, though for such (relatively) low torque figures a larger torque wrench is likely to be cheaper than a multiplier.
lambert.the.farmer Member Since: 11 Apr 2012 Location: harrogate Posts: 2006 ![]() ![]() ![]() |
I have a set of 3 toolzone ones in 1/4 , 3/8 and 1/2 drive. Yes they are cheap but they are accurate enough for car jobs. Only issue is they're all metric so I have to occasionally convert units. Rhubarb and custard let fly with their secret weapon.
ChrisCM Member Since: 10 Jun 2013 Location: Cornwall uk Posts: 572 ![]() ![]() ![]() |
Thanks Guys, for all the replays and info, I like the look of this Teng Tools one :
http://www.ebay.co.uk/itm/Teng-Tools-1-2-D...n7MOX71Hig Also has an angle gauge but whether I'd ever be brave enough to tackle a job which requires this I doubt. What do you think? Chris 2010 Defender 110 Station Wagon, Santorini Black. |
TD5 clutch, for example. |
