Home > My Defender > Puma 130
Page 2 of 2 <12
bcarlin
what is the load rating of the boosts? rear axle weight is 2200kgs
Post #629772 7th Jun 2017 9:06pm
950, or maybe 975 comes to mind. Regardless though, the reason Land Rover never offered them on the 130 is that they're not rated for the GVW.
As far as I know, Blindos are the only Land Rover alloy that would be up to the job but there may be aftermarket wheels that would also do. Darren
Post #629833 8th Jun 2017 7:32am
Thon
I don't think Blindos are offered by Land Rover. They are as aftermarket as any. You could also consider the Evo Corse version (sold in UK as Terrafirma Dakar), which are often used by UK military WMIK in place of Blindos? Both look suitably purposeful and are slightly less likely to give you a hernia when fitting them...
Post #629844 8th Jun 2017 8:00am
You might be right about the Blindos. I know they are specced for specialist military stuff (WIMK, etc) but I guess even those conversions are 'aftermarket'. I guess they're Land Rover approved though, as those sorts of conversion rarely happen in isolation. Darren
Post #629849 8th Jun 2017 8:15am
It's way more than that, I think around 1750kg or 1800kg per wheel, otherwise you couldn't run them on a 90, let alone a 110.
Usually each wheel's load rating will be around the same as the gross axle weight of the stongest axle on the vehicle, hence the use of "Wolf" steels, load rating 2200kg, on the 130 and HD 110 versions (ie the 3500kg GVW vehicles). The 3040kg GVW vehicles (ie standard 110) can run Boosts.
I have never actually found the official load rating for a Boost, however.
Post #629850 8th Jun 2017 8:18am
I'm sure you're right when allowing for a safety factor, but I've seen Tornado (Freestyle) wheels that are stamped 850kg on the inside. The published load ratings for Blindos are 1550, which suggests that typically, load ratings are not given in relation to total axle weight. Darren
Post #629862 8th Jun 2017 8:44am
Thon
Yes, you're probably right about them being LR approved, although the later WMIKs are not exactly "normal" LR as they have auto boxes and 2.8 TDI motors ... without even considering the honking great gun on top ... Shocked
Definitely top-notch wheels either way Thumbs Up
I only went for the Dakar's because a set came up (very) locally - didn't even need to use surfaced roads - at an excellent price Very Happy
Post #629867 8th Jun 2017 9:00am
mi-cap
I think you get the max axle weight from the vin tag and then half it for each wheel.
Post #629870 8th Jun 2017 9:14am
bcarlin
Thanks for the help this, my rear axle weight is 2200kgs
Post #629881 8th Jun 2017 9:51am
You're right, I've looked up the figures I have (which I should have done before posting above of course) and find the following:-
Blindos: 1550kg
Defender HD steel ("Wolf"), tube type, ANR5593: 2200kg
Defender HD steel ("Wolf"), tubeless type, ANR4583: 2200kg
Defender steel, tube type, NRC7578: 1241kg
Defender steel, tubeless type, ANR4636: 1241kg
Defender 130 (early) (Rapier, Snatch 110), ANR1534: 1372kg
Disco 1 steel, NTC5193: 1340kg
Although I have a considerable amount of information about just about every type of OE wheel used on every type of Landrover, these are the only load ratings I have been able to pin down.
On this basis I would expect a Boost or a Deep Dish to be around the 1200kg mark.
Post #629921 8th Jun 2017 11:47am
bcarlin
So why can't boosts be fitted ?
Post #629923 8th Jun 2017 11:51am
As I said above, LR never offered them on the 130 as they're not up to the job. I'm sure I've seen somewhere that they're rated at 9 hundred and something but I can't find the reference now Confused Darren
Post #629927 8th Jun 2017 12:01pm
bcarlin
Seats getting recovered, bought from ex moor trim, cubby to match and a momo steering wheel
Post #630260 9th Jun 2017 9:03pm
bcarlin
Seats completed, cubby box in and a momo steering wheel added today
Post #630454 10th Jun 2017 8:41pm
Page 2 of 2 <12
