![]() | Home > V8 > Which one? |
Ooh watching with interest, sounds a perfectly amazing project!!
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 ![]() ![]() ![]() |
4 litre Thor is, IMV, the best LRV8, the best injection system, cross bolted bottom end and relatively bomb proof. Buy a P38 with an MOT and, if you're of a mind to, you can cover the cost by selling off the lights, ECUs, diffs and compressor from the P38 before weighing it in.
Similar with the 4.6 but they seem to be rarer and I don't think they are as reliable but I'm sure others will disagree ![]() It's a perfect engine for Megasquirt too as everything you need is already there, especially if you're going auto. Just needs wiring and an MS ECU with coil drivers. http://www.yorkshireoffroadclub.net/ |
