Home > Maintenance & Modifications > 2007 puma seal below windscreen leaking
Les
The soft seal that runs across bulkhead is leaking on the left hand side - I can just see drips when its raining. Im sure this is a common problem so my question is whats the best or easiest fix?
Is there something I can do without removing whole dash?
Thanks
Post #626594 24th May 2017 2:07pm
dorsetsmith
Post #626595 24th May 2017 2:10pm
Les
Thanks
Looks like test L and apply clear sealant on the outside of the seal
I'll try at weekend
Post #626597 24th May 2017 2:21pm
Harry.O
I ran a bead of Sikaflex along mine and it's not leaked since. Put a dob behind the windscreen hinge brackets as a precaution also.
Personally I wouldn't use silicon, it's horrible to remove totally if you want to re-paint the vehicle at a later date.
Post #626598 24th May 2017 2:25pm
Les
Thanks
Was that along the outside of the seal?
I guess you can buy clear - its a grey defender
Post #626605 24th May 2017 3:14pm
dorsetsmith
Sikaflex in black
Post #626606 24th May 2017 3:28pm
julianf7
Apologies for the newbie question, but which Sikaflex do you recommend here? There are so many types from which to choose..
Post #626616 24th May 2017 4:18pm
dorsetsmith
Sikaflex 291i Marine Adhesive & Sealant in gray too
https://www.defender2.net/gallery/albums/u...281%29.pdf
Post #626622 24th May 2017 4:56pm
julianf7
Many thanks, ordered it up
Post #626784 25th May 2017 9:34am
Harry.O
Les wrote:
Thanks
I used the same stuff as Dorsetsmith and no complaints so far. Mask the area externally before you apply the Sikaflex then wipe excess off with a wet finger before removing the masking. You can paint over the 291i version as well Thumbs Up
Post #626793 25th May 2017 10:16am
agentmulder
Kuwait
Just a little story... I thought this was my leak too but it turns out it was actually the seal between the windshield frame and the roof !
The water would run a small way along the 'inside' gutter (behind the roof trim where the cables run) then down a piece of the roof casting on to the door seal then down the inside of the door seal behind the plastic trim of the A-pillar until it hit the seal you're taking about then do it's drippy thing... Solved the bowel problem, working on the consonants...
Post #626863 25th May 2017 5:34pm
zsd-puma
If you're going to use sikaflex type stuff, use one that' over paintable, anything else is likely to cause massive problems should you wish to do any painting later on.
I've used some of this on mine...
http://www.ebay.co.uk/itm/171234457522
Worked a treat.
Post #626866 25th May 2017 5:37pm
