Home > Td5 > Squeeking clutch
Maarten
South Africa 2002 Defender 110 Td5 SW Alpine White
Squeeking clutch
Hi all,The clutch pedal on my 2002 TD5 is squeeking.I have read sometime ago about the solution but I cannot find it now.Anybody has any ideas?If I remember correctly,it has something to do with opening the box next to the clutch fluid reservoir and doing something there but I am not quite sure what.Thanks for your help.Maarten
Post #620731 1st May 2017 12:49pm
ChrisWoods
United Kingdom 2009 Defender 110 Puma 2.4 USW Aintree Green
Yeh, it'll either be the pin that the pedal pivots on or the spring. Both need lubrication. Heavy grease. WD40 just doesn't work. 2009 2.4TDCi XS Utility Wagon.
Post #620756 1st May 2017 2:51pm
Maarten
Thanks for the lead.
Post #620758 1st May 2017 2:57pm
