Home > Puma (Tdci) > Brake pad change.
Vitesse
Brake pad change.
Hi. I need to change (myself) the front and rear pads on my 2015 90xs. Local dealer want about 150 pounds to supply the parts!!
Just interested what other forum members have done? I have shopped about and can get the whole lot for about 76 pounds elsewhere. Brembo brand. I have found other brands even cheaper but may not be any good any advice welcome. Thanks. Brian 2015 90 XS Santorini Black
Post #619903 27th Apr 2017 1:24pm
meeerrrk
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Very easy task, for sure do it yourself.
You can get pads from the like of euro Car parts just make sure you get a good discount code first!
Brembo are a good reliable brand, most people seem to recommend mintex.
£75 sounds about right for all pads. My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #619914 27th Apr 2017 2:28pm
rustandoil
I Use EBC Green stuff pad on my 110, not sure of current price, I got mine from Paddocks
Post #619923 27th Apr 2017 3:13pm
Vitesse
many thanks! Thumbs Up 2015 90 XS Santorini Black
Post #619943 27th Apr 2017 4:08pm
geobloke
As with Eddie. Work well, never rattle or screech big Thumbs Up for EBC pads...
Which reminds me I should order a fresh set as I am 1/2 way through these.
I would recommend you buy this
http://www.drbcarspares.co.uk/draper-brake...2699-p.asp
as it will make the job much easier and reduce the risk of damaging the piston seals. Also take your time cleaning the crud off from the pistons before you retract them.
Post #619944 27th Apr 2017 4:09pm
LR90XS2011
EBC
Thumbs Up
But cut out the middle man and go straight to their own web site DEFENDER 90 TDCI XS,
Post #619959 27th Apr 2017 5:06pm
grafty99
Pagid pads are also good Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #619965 27th Apr 2017 5:55pm
barbel jim
Not that impressed with the green stuff, especially for the extra£££ create alot of dust, and no noticable benefit, even when towing. Pagid in the rears (euro carparts) Thumbs Up but I have just reverted back to mintex up front
Post #619966 27th Apr 2017 5:59pm
agentmulder
Kuwait
Ang-a-nang-on...
Yes, very easy, buuut one thing to check:
If your pads are very worn then they would have been operating for a long time with the pistons exposed to the elements. When installing new pads you'll have to force the pistons back for them to fit (g-clamp and appropriate flat bar), thereby forcing crud in to the piston seals. This may or may not cause a seized piston, reducing brake efficiency or brake failure in the worst case.
Personally, I'd be doing a check of the piston condition at the same time.
In my case, I found I needed to replace the rotors as well, so a simple pad swap equated to hub off and a full caliper rebuild. Solved the bowel problem, working on the consonants...
Post #619985 27th Apr 2017 8:19pm
zsd-puma
I agree, i've got Mintex at the moment, they're ok, but squeal a bit. Mintex and Pagid are made by the same company. But Mintex are now their budget brand (save for a few specialist compounds) and Pagid are their premium brand. I've used pagid in my previous L322 and other cars. They were silent as a mouse with a nice fast bed in time.
It's worth getting a fitting kit too, they're between £3 and £10 depending where you get them, but it saves the hassle of reusing scabby springs and trying to find spit pins.
Take it to Kwikfit etc for one of their free brake checks. They'll tell you what needs doing, then you can do it yourself, it's what i do. Laughing
Post #619994 27th Apr 2017 8:34pm
mick
England 2010 Defender 130 Puma 2.4 HCPU Rimini Red
Ferodo takes about 30 to 40 mins to do don't get mintex
Post #620001 27th Apr 2017 8:46pm
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
EBC greenstuff is for fast road use. You have to warm them up before they work! Try blackstuff that works straight away for 'normal' road use. That's what I'm using and quite like them! 1953 80"
1987 mini city e
2011 90"
Post #620015 27th Apr 2017 9:34pm
I've got greenstuff, and quite happy with them.
Have been for a while.
Definitely worth getting the split pins etc too.
Personally, this is just me but I'd get someone to do the pad change.
At least then you know you could never be accused of anything should the worst ever happen. WeWillWin🇬🇧🇺🇸
⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #620018 27th Apr 2017 9:42pm
mick
I get your point but on the other hand there not hard to do and if you do it yourself you know it's done correct and you could always take pics.
I've seen some proper crap work over the years from so called technicians
Post #620025 27th Apr 2017 10:26pm
Indeed, depends on self confidence and skill. I think most people here know their boundarys of capacity of capability. If you feel happy and capable go for it. 👍🏻 WeWillWin🇬🇧🇺🇸
Post #620028 27th Apr 2017 10:51pm
