Home > Maintenance & Modifications > Puma Diffs
Page 1 of 3 123>
Bristol 90XS
Puma Diffs
Quick question having just done a search and getting differing answers..
Does anyone know definitively if the front diff on a Puma is a 4 pin diff or is it a 2 pin diff? Is there any way to check aside from taking it apart?
Its a 2014 110 SW.
Need to know as might need to upgrade it with the forthcoming power upgrade Very Happy
James
Post #617559 17th Apr 2017 9:17pm
I can't give a definitive guaranteed answer.
But I'm pretty sure it's the rear that is 2 pin only. No Guts, No Glory.
Post #617570 17th Apr 2017 9:49pm
Front is two gear on 90s, and most 110s and 130s it seems. In theory post c.2010 all LWB fronts should be four gear but many are still two.
Reats on 90s are two gear Rover pattern, on 110 and 130 four gear P38.
Front diff can be identified as 2 or 4 by looking through filler hole.
Post #617572 17th Apr 2017 10:00pm
Bristol 90XS
Thanks blackwolf- that most likely explains the issue.
Amongst other conflicting guidance Ashcroft are saying it's 2 pin front and I should upgrade but my local LR me hanic who has worked land rovers all his life is saying 4 pin. He changed the oil at last service too so maybe he's had a look in. I'll ask him to check at next service.
James
Post #617580 17th Apr 2017 10:27pm
jst
As black wolf says above.
10my onwards 110 fronts were all meant to be 4 pin. Although on stripping my oct 10 110 had a two pin!
Likewise the 110s at work, 13 14 plate were also a mix front. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #617592 18th Apr 2017 6:16am
LR90XS2011
it should be recorded on your build sheet ask LRCR or the selling dealer for a copy. DEFENDER 90 TDCI XS,
Post #617594 18th Apr 2017 6:21am
You'll know it't a two gear diff when it disintegrates, but that is usually a bit late!
Fit an Ashcroft ATB and put an end to your worries. When I did mine it was also cheaper than a reconditioned four gear diff from LR.
Post #617602 18th Apr 2017 7:19am
^^ I did the same on my 2010 110 defender, front 2 pin, rear 4 pin, now running front and rear Ashcroft LSD's Thumbs Up
Post #617607 18th Apr 2017 7:46am
Bristol 90XS
Have been looking at the Ashcroft LSD. Ashcroft saying they are t any stronger than the 4-pin std diff assuming my I have one.
But how do they drive? Am going to be putting about 430bhp and twice the torque through them shortly so am thinking an lsd might help with traction but have heard it makes the car less nice to drive and grabby? Interested in your take on tem BO Man.
Thanks
James
Post #617627 18th Apr 2017 9:42am
jst
i would fit an ashcrfot locker then for that Nm/bhp irresepctive of whether you plumb it in. might want to peg diffs too and assume CV shafts already on the list? Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #617657 18th Apr 2017 11:33am
JOW240725
James, not sure if you've seen this thread on the LSD, but seems to cover most views http://www.defender2.net/forum/topic13545.html?highlight=lsd
John Fair also has some interesting comments on diffs here http://www.defender2.net/forum/topic46611-60.html James
Instagram @suffolk_rovers
Post #617659 18th Apr 2017 11:41am
Bristol 90XS (James) I agree with JST using lockers rather than LSDs for that much BHP, however for the record, the Ashcroft LSDs make virtually no difference to the defender "driving experience", I use mine on and off road, and on wet grassy slopes you can feel the LSDs working.
Post #617664 18th Apr 2017 11:58am
JOW240725
Would I be right in thinking you'd only ever want full lockers off-road? Therefore if (and apologies James if I'm making the incorrect assumption) this is a road biased V8 Defender then LSD would surely be the better option? James
Post #617672 18th Apr 2017 12:14pm
jst
for strength i believe the locker is better for longevity. but yes only really off road usage. although rear could be used to put power down. you just need to control it.
i have air lockers in mine front and rear. the rear being the hypoid diff from Dave A crown wheel/pinion is much better than stock before you even look at the centres. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #617673 18th Apr 2017 12:17pm
Caterham
Thanks
James
I'm guessing that'll be more than a stage 1 or 2 remap then Very Happy
Post #617734 18th Apr 2017 5:07pm
Page 1 of 3 123>
