![]() | Home > Maintenance & Modifications > Defender 90 - Auxiliary Power |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5082 ![]() ![]() ![]() |
Apparently there is a feed in the rear - ive got to investigate an fit a socket. Mike
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
Guys,, see page 3 on my 110 thread http://www.defender2.net/forum/topic20-30.html about rear Aux sockets California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Main Brian James Trailer Dealer for South West UK |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 ![]() ![]() ![]() |
More or less ditto here,,
But did you look on the right hand side, ![]() Main Brian James Trailer Dealer for South West UK |
Didn't look behind the right hand panel but will sometime in the next week when I fit the wheel carrier. I'd rather have the sockets to the left side of the door as they are more accessible. Also I wanted to run heavier cable direct from the second battery to the rear. 110 2.4TDCi
110 300Tdi ![]() LROCV ::: AULRO.com |
I had a look on Sunday - realised i looked on the left not right side, i did think at the time as the right side is the main harness side. One thing i did notice is removal of the speaker, how did you guys get it out - is there a trick? Mike |
If you mean the speaker panel,, Their are 2/3 panel clips in the lower edge, pull back carpet, and remove the clips, then carefully lever out from the bottom, then comes out California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
Not in the Australian ones. Obviously it costs more to import carpet and MP3 compatible CD/Radio units ![]() The top section of the speaker panel is double sided taped to the bottom of the window surround and comes off easy enough. 110 2.4TDCi 110 300Tdi ![]() LROCV ::: AULRO.com |
Fitted a socket today.
Bit of a pain job as the trim really didnt want to come out despite the 3 clips being removed and the carpet back. Anyway purple and black cable and connector found - 12v feed - small harness made using 25amp cable, hole drilled socket connected to purple and all refitted - works a treat thanks for that. A few issues on my behalf fitting, but still done and all good. So am i correct 20amps fused under the seat for that feed? Also does the ecu monitor battery levels and shut down applications if voltage drops? Mike |
Yep, a separate fuse box, under the RH (Drivers) seat, with the main box, holding 2 fuses,, their is also meant to be another one, halfway back down the vehicle,, but have yet to find it !!! I had no power at this feed to start with,, Under the bonnet, near the servo, is a butt connector,with this Purple/Black wire,, mine was dickey from new !! Very much doubt if the ecu will shut down power to the aux feed, if low volts,, With the Engle fridge, i run one of those low voltage leads ,, however these kill the power too soon,, i have had it shut down, then bypassed it overnight, and the 110 still started fine in the morning !!! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK Last edited by TJ101 on 28th Sep 2008 9:19pm. Edited 1 time in total |
Mine was all ready to go nothing required which was nice - well put it this way 12v read and the search light worked.
Be good if the ecu did that - the vw's we used to have did, meant you could always start the car! - I dont doubt there may be one mid way, more on the 110 - but i would doubt it on the 90. Whats it actually for anyway? Mike |
