Home > Td5 > EGR Cooler Coolant Hose Bypass |
Hold fire I am drawing my coolant today, will have a look for you...
13th Apr 2017 9:11am |
adeparko Member Since: 13 Feb 2015 Location: West Lothian Posts: 41 |
That would be great, thank you
13th Apr 2017 9:24am |
No problem at all will be end of the day though when I come back in
13th Apr 2017 9:28am |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2179 |
Since your there, would you be able to measure the diameter of the coolant pipe rubber hose thats runs into the oil cooler?
Click image to enlarge PBH listed on there |
13th Apr 2017 9:46am |
Dear lord anyone else... Got a job on yer know
13th Apr 2017 12:27pm |
Thank you
13th Apr 2017 12:47pm |
,photos uploading... Hold fire gents....
13th Apr 2017 5:47pm |
Here you go adeparko. the measurement was of the metal pipes OD. The inlet and outlet are the same diameter. Click image to enlarge Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
13th Apr 2017 8:08pm |
Hi bankz5152 here you go. The pipe has two different OD. So a reducer pipe. Click image to enlarge Click image to enlarge Click image to enlarge |
13th Apr 2017 8:29pm |
Thats amazing, thank you so much for the help
14th Apr 2017 7:44am |
Amazing! Top fella, cheers!!
14th Apr 2017 7:56pm |
Anytime gents. Good luck with your repairs...
14th Apr 2017 8:56pm |
