Home > Maintenance & Modifications > Track Rod End?
dancerdave
United Kingdom 2000 Defender 90 Td5 Exclusive HT Santorini Black
Track Rod End?
I have a set of heavy duty steering bars I was given by a friend and do not know the make. The problem is that i need a track rod end and these are bigger than standard. Both QT and Sumo use the standard size LR tre's so unless anyone has a suggestion I'll have to junk them Question
The nut on the end of the bars is 27mm if that helps
Post #613603 31st Mar 2017 3:12pm
sako243
Have you tried seeing if a standard one would fit? I'd be surprised if it used a different one and was intended to fit on an LR as they'd have to do some hunting to find a different one from standard.
My HD one has a big nut on it (probably 27mm like yours) but still takes standard TREs. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #613740 1st Apr 2017 8:48am
dancerdave
Yes it's larger thread. Looks like I'm buying new steering bars as well Big Cry
Post #613757 1st Apr 2017 10:49am
ickle
I think mine had Lemforder ends, but I never kept the boxes sorry.
Post #613781 1st Apr 2017 12:53pm
