Home > Technical > Quick disconnect unions that are stuck
Dingo
BACKGROUND
07 Puma, with fuel starvation problems after running for 5 to 10 minutes. Worse with a trailer.
I have replaced the fuel filter (R rear wheel arch) twice in three months with no improvement, so the suggestion is a blockage in the pickup in the tank.
The tank was removed, steam cleaned, new rollover tube, about 6 months ago to cure the starvation. Worked OK for a while, but starvation has returned incrementally.
I am now trying to blow back from the fuel filter towards the tanks with a gentle air line, to listen for a bublling sound to show the supply line is clear. There are two fuel lines between the tank and the filter; one thick, one thin, and they have different quick connect fittings.
The thin line disconnects easily by pressing the two blue dots and moving the union fowards and backwards. I guess this is the return line to the tank.
PROBLEM
The thick (supply ?) line has a bigger connector with a single blue patch. Pressing this (after blowing muck away with an air line and brush) enable the union to move to and fro about 3mm. But does not release. I cannot see a safety clip or similar additional clip on the union, just one blue rectangle.
What am I doing wrong please ? And if, as it just about possible, the QD union is knackerd and jammed, how best to replace and refit one please ?
Of course, my runabout Berlingo has also gone on strike in sympathy with a suspension problem . Cars, doncha love 'em ?
thanks guys.
Post #613254 30th Mar 2017 10:45am
dorsetsmith
this may help with parts
https://www.landroverworkshop.com/diagrams...ines_45021
sound like fuel bug
Post #613287 30th Mar 2017 12:30pm
Dingo
FIXED IT ! Very Happy
The connector that stuck is the one with the long blue tab on the fat tube.
I guess that when the tank was taken out some time ago, the pipes were pulled tight, giving an angle towards the centreline of the chassis.
I blew an airline with a bit more force onto the connector to dislodge any residual gritty bits, then gave a tiny squirt of sacred WD40.
Pressed the blue tab down hard with the shaft of a screwdriver rather than a squishy thumb, and then wiggled the connector in all directions.
As soon as I got the fuel supply pipe in alignment with the spigot of the filter head, the fitting clicked off easily.
Puffed air back down the supply line; slow bubbles heard at first, then quicker ones. And I then reconnected everything. And practised taking it off again - seeemples when you know how !
Time taken in failing - about 2.5 hours. When it all worked properly - about 10 minutes !
I am back in love with my Landrover :)
Post #613310 30th Mar 2017 2:59pm
dorsetsmith
Confused are you saying it will only run for 2. 1/2 hr
Post #613318 30th Mar 2017 3:41pm
