![]() | Home > Td5 > Defender ABS rear brake tone ring |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 925 ![]() ![]() ![]() |
The ABS ring should unbolt and with quality replacement discs will have the holes in them to allow you to bolt the rings back in. SDB000330 if you google it you will see various discs with the correct holes. IMHO if your not sure ask the manufacturer before shelling out on your hard earned Wonga.
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 819 ![]() ![]() ![]() |
Ive just replaced my rear discs with EBC slotted and drilled discs, these had the ABS ring holes drilled...
