Home > Puma (Tdci) > Just had my first problems
Page 2 of 2 <12
dgardel
Italy
Re: Just had my first problems
Opsssss
But BAS remap and Alive Tunning re-map use the same system (the Italian Alientech)
Embarassed Embarassed Whistle Whistle Mr. Green Mr. Green
dgardel wrote:
Glynparry25 wrote:
After 1.5 years of hassle free motoring I have had me first problem Big Cry Pluged her in and got this Shocked :
I am old school engines... not so much this ECU telling me what to do. Anyhow 10 mins on Google got me this:
Download this one https://files.me.com/daniele.gardellin/vbutqe your P1103 isn't correct!!!
P167B- Fuel Injector Learning Not Done you have done Q068 but dealer do not done injectors learning (same mounths ago LR system given errors on this procedure)
P0562- System Voltage Low battery related to the cold temp not a real problem
P068A- CM/PCM Power Relay De-Energized Performance - Too Early see previous point
P0234- Turbocharger/Supercharger "A" Overboost Condition normal on all Puma that I have seen
P1103- Mass Air Flow Sensor In Range But Higher Than Expected normal on all Puma that I have seen
P0100- Mass or Volume Air Flow "A" Circuit related to BAS remap but not really a problem new version are ok now, write to Pete
P0299- Turbocharger/Supercharger "A" Underboost Condition normal on all Puma that I have seen
U0001- High Speed CAN Communication Bus related to BAS remap but not really a problem new version are ok now, write to Pete
P1643- CAN link to ABS ECU.Implausible signal/condition
U0300- Internal Control Module Software Incompatibility related to BAS remap but not really a problem new version are ok now, write to Pete
 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #55506 28th Jan 2011 3:43pm
Page 2 of 2 <12
