Home > Series Land Rovers > Where is best for paint
Stacey007
Hello
I've ordered some more parts from Paddocks (non exciting just two lap belts) and added a tin of Limestone as may have a go at the wheels changing the 750 rims from white to Limestone.
I also had a quote from the Paintman for Marine blue paint, I notice Paddocks sell this also.
Any difference or preferences between the two? The Paddocks HMG or the Paintmans
Thanks
Post #605075 26th Feb 2017 8:34pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Spraying or brushing?? 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #605087 26th Feb 2017 8:50pm
Paragon Paints Thumbs Up
Post #605088 26th Feb 2017 8:51pm
Stacey007
Hello
Initially I'm going to have a go at brushing / roller
Searching the web suggest good results and I can at least have a go, proper spray job will be many pennies...
Does that alter what I choose?
I've e-mailed the other company thanks for a quote as the colour was not in the LR choice they had.
Post #605146 26th Feb 2017 10:21pm
ian series 1
As Greeni said, Paragon come up quite a lot on this subject.
I've seen lots of hand painted series land rovers, some plain ugly, some you would find it hard to know if it was sprayed or brushed.
A good coach enamel flatted between coats will give a good Results, take your time with the prep work and you will get a good Finnish.
Tractol is quite a popular one too. Thumbs Up 80" 80" 86" 88" 90"
Post #605177 27th Feb 2017 7:16am
Ellisboy
1998 Defender 90 300 Tdi CSW Epsom Green
I have used the paint man paint for my grandsons toylander with good results.You need to buy a really good bristle brush ,like a Hamilton.i rolled it on and then brushed it over.You need to do it in a well ventilated area though as it's coach enamel and quite potent Thumbs Up
Stephen.
Post #605178 27th Feb 2017 7:21am
xcentric
Do it badly, and you get something more akin to a Russian.....
Post #605197 27th Feb 2017 9:00am
milesr3
2016 Defender 90 Puma 2.2 XS CSW Keswick Green
Paintman paints are the most expensive and I've seen reference to his paint being supplied by HMG.
I used Tekaloid T318 and as Ian says Tractol is another popular choice. I bought all my paint from Avenue Coatings via their tools-paint website: http://tools-paint.com/commercial-vehicles...2783-c.asp
You can get a decent finish with a glossing roller to get an even coat and then brush out with a high quality brush. It can be wet flatted before, in-between and after each coat. Preparation of the underlying surface is everything.
Mine ended up with a very slight orange peel after 3 coats of Tekaloid, which I could flat out and polish if I was really bothered by it, but it's fine on my battered old truck:
[/URL][/url]
Post #605203 27th Feb 2017 9:34am
ian series 1
My 52 80" was hand painted, not by me but the previous owner,
And apart from a few little bits here and there I don't think he did a bad job?
Some areas are starting to lift slightly but that's just down to wear and tear, stone chips etc.
 80" 80" 86" 88" 90"
Post #605205 27th Feb 2017 10:20am
MGCarr
United Kingdom 1997 Defender 90 300 Tdi PU Rioja Red
I have used Paintman paints for brushing and they seem to be good to use but I am no expert. Unfortunately he is about to go from expensive to very expensive as he is putting his prices up by 20% on the first of March, he says this due to having to become VAT registered which is a bit weird.?
Post #605239 27th Feb 2017 12:44pm
Tinytim
I have used paddocks hmg limestone paint for brush/roller painting and have not had too many problems. It does need thinning down slightly but has good coverage. I am in the process of painting a set of rims , the previous ones done in the same paint have lasted about 10 years. Two things I noticed was that you can't lacquer the paint as it crazed and is a bit soft round the wheel stud holes, but not sure if that is down the paint or the choice of primer.
Here is one of the wheels I have started with one coat of limestone
Post #605248 27th Feb 2017 1:03pm
xcentric
Why weird? - if he turns over more than the VAT threshold, then he has to add VAT..... yes, he can reclaim it on inputs, but may not have that many - so the cost is going to go up....
Post #605319 27th Feb 2017 7:24pm
MGCarr
I thought it wiered in that prices where going up by the same as the VAT which seemed like he was not factoring in the reduction of his costs resulting from him now being able to recover the VAT on his business expenses that he had previously not been able to recover.
Post #605632 28th Feb 2017 9:45pm
Mass
I've used the Paintman from Doncaster for brush on enamel..
Post #607387 6th Mar 2017 10:39pm
