Home > Puma (Tdci) > Oil leak below radiatior |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5035 |
Power steering i bet
check the reservoir - sometimes the pipe clip needs tightening the other one that was an issue years ago was brake system related and that was on the left side front/mid engine if i remember all those years ago - but it was a recall job Mike |
24th Feb 2017 6:39pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1777 |
As above, power steering - be careful as the fluid reacts with the rubber ball joint cover and will make it fail.
Keith |
24th Feb 2017 8:31pm |
