Home > Technical > Click-clack form the wipers
Page 2 of 2 <12
If you run with them loose long enough they will jam, however usually they can be unjammed by waggling the wiper arm. I have had this happen to me.
If you are unlucky enough to have a wiper actually jam, remember to sort it out asap since even with the wiper switch in the off position the motor will be trying to park the wipers. Although there is (allegedly) thermal protection on the motor, your problems would become much more expensive if you manage to burn the motor out.
Also remember when you waggle the wiper that if the ignition is on the wipers will mimediately park when unjammed, so watch out for those digits!
In extremis (and obviously not for road use) if you have one wiper which is jamming repeatedly due to a worn wheelbox, if you remove that arm from its spindle it will then generall allow the other wiper to run normally (the unloaded spindle generally won't jam). This may get you out of trouble. Since the wipers only run through a 120 degree arc, you can also remove the arms, pull the drive rack out, rotate the spindles 180 degrees, do the same for the rack in the motor gearbox, and refit, and a new unworn part of the rack will be engaged with an unworn sector of the spindle drive gear in the wheelbox. Again this should buy you a few thousand miles of time. It isn't a long term solution since part of the wear will be to the area of the wheelbox that holds the rack engaged with the gear, and this can only be altered by removing the wheelbox.
Post #604464 24th Feb 2017 11:00am
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
Martin wrote:
The wheelboxes fail by going loose rather than jamming
I must admit my wheelboxes seized up with the white aluminium corrosion. so when i replaced them i put plenty of grease around them!
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #604495 24th Feb 2017 1:04pm
Ah, I've not had that happen, but that would cause total, unfixable seizure!
Post #604503 24th Feb 2017 1:25pm
Hufflepuff
Mine had gone slow due to friction from rust inside the spindle. The wiper struggled to start turning them (I used to help them by hand until they had done a cycle) and then they'd be OK for the rest of the day. Leave them off for a couple of days and they'd be stuck again.
When I replaced them I couldn't even turn the one side by hand off the vehicle, so fair play to the wiper motor for doing as well as it did. Ended up replacing the lot, wiper motor with park switch, cable and the two wiper boxes. No more clackety clak Smile
Post #604506 24th Feb 2017 1:39pm
zsd-puma
Normally they seize solid on vehicles that aren't used frequently.
But use them too much and they wear out. Laughing
Post #604512 24th Feb 2017 2:00pm
Cupboard
Typical Land Rover, use it and it breaks, don't use it and it breaks Rolling with laughter
Post #604723 25th Feb 2017 12:05pm
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
As the folks have said above, probably the wheelboxes.
Eventually the wiper rack will miss the teeth and stick- I had to sort this last year on my 05' TD5.
As a temporary fix you can put the rack out, cover it in loads of grease, rotate the wheelboxes through 180 degrees using the spindles on the outside and then reassemble.
When you do change the wiper wheels and the rack be prepared for a couple of hours of hand punishing misery- if you can find an assistant with small hands and a fantastic memory to remember where all the ever-so-slightly different screws go I'd thoroughly recommend it.
Even after doing this mine slap about a bit- and this is due to the wear in the worm drive and cambox on the wiper motor- I have decided that using Rain X regularly is a cheap solution to this for now......
Chris
Post #604754 25th Feb 2017 3:57pm
And in between it'll corrode. Rolling with laughter TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #604761 25th Feb 2017 4:07pm
agentmulder
Kuwait
I've got the same, discussed recently in another thread.
Parts are in the mail (got the rack too, but not switch will try to refurbish that myself if need be), if I have time I'll photograph the fix process.. Solved the bowel problem, working on the consonants...
Post #604821 25th Feb 2017 7:41pm
explore
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Stornoway Grey
Had a wheel box seize up on my 2011 Defender, never had happen it on any of my previous Land Rovers
Post #604947 26th Feb 2017 1:05pm
ChrisWoods
United Kingdom 2009 Defender 110 Puma 2.4 USW Aintree Green
You should be able to get 2 used out of each rack and each wheelbox by turning them 180 degrees. Mine lasted 95,000 miles. You can only very slightly hear them of the engines off but running you can't hear a thing. 2009 2.4TDCi XS Utility Wagon.
Post #608895 12th Mar 2017 4:34pm
Page 2 of 2 <12
