xcentric
so still have problems - having stripped off all the old connections, I now have what appears to be + and -ve connections for all lights, plus another thinker black lead that goes to earth. I don't quite understand why there is this other lead - it appears to be separate (at least, it comes out of the loom separate) to all the other leads - so a bit confused.
I also can't find a route from any positive back to the battery - connecting a circuit test between sidelight/indicator/side repeater + and either their respective - or the black earth one, or both, still shows no connection - which if I'd not turned on lights or indicators would be right, but is certainly odd when they are on.....
any ideas?
23rd Feb 2017 4:11pm |
xcentric
solved: like most things electrical on a Defender, it was a ground problem. Studied the wiring diagram, re-sorted the ground attachments, re-made all the electrical bullet terminations and connectors (bullet connector kit off eBay for about a fiver) and it's all working now. The -ve returns do attach to the earth cables somewheere in the wiring loom, so it has to be well earthed.....
Just got to put it back together again.
24th Feb 2017 11:48pm |
xcentric
back together, only 2 screws and a washer spare and it all works.
26th Feb 2017 2:03pm |
shaggydog
27th Feb 2017 12:38pm |
