Home > Series Land Rovers > New Wheels for my Series III |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 |
James
MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
11th Feb 2017 4:28pm |
milesr3 Member Since: 12 Feb 2013 Location: Suffolk Posts: 873 |
Take off standard wheels with Michelin latitudes are perfect 👌
11th Feb 2017 5:02pm |
Spectre Member Since: 26 Jan 2016 Location: South East Posts: 228 |
Pics of your Series III please!!
11th Feb 2017 6:31pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3784 |
Its nothing to write home about
but its got character, here its is, still at the garage having parts fitted, Click image to enlarge |
11th Feb 2017 7:50pm |
Looking forward to more photos once you get the parts fitted up
11th Feb 2017 10:12pm |
Andy80 Member Since: 31 May 2013 Location: Essex Posts: 490 |
Pity to put larger 750 radials on when it look so cute on 600x16 Working towards Carry on camping! |
12th Feb 2017 8:13am |
You'll be needing a long wheelbase speedo to go with those 7.50's. Darren
12th Feb 2017 9:55am |
^ How much difference will it be?
Will it under read or over read. Loads of people do this so must be fairly common? used a quick calculation web site , not sure of the height of each Tyre though so came in as original at 30 mph the new ones the speedo would read 27 mph I'm happy if its under lets be honest 50 Mph would seem fast in this so if its reads 45 for example I can live with that. |
12th Feb 2017 4:49pm |
It'll read under by about 12% from memory which, apart from being illegal, is an easy way to find yourself breaking the speed limit, e.g. you think you're doing 30 when you're closer to 35.
If it was the other way around then it's legal for a speedo to over-read by up to 10%. Yes, loads of people do it and the fix is quite easy, which is to fit a speedo from a LWB model. Unlike later models, the gearing for the speedo drive is within the speedo itself and is indicated by a small four digit number along the bottom edge of the dial. I can't remember the exact numbers off hand (I last did this mod 25 years ago ) but it's something like 14xx for a SWB and 11xx or possibly 12xx for a LWB. I'm sure that Google will be your friend to confirm the details. One of the small niceties of doing this is that it's relatively easy to change the odometer to match the existing. The glass face comes off and then the figures can be flicked around with a pencil or cocktail stick. Whilst some will frown upon this, it's difficult to imagine getting excited about the accuracy of the mileage on an ordinary vehicle of this vintage. I suspect the hardest part may be finding a suitable LWB speedo... Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
12th Feb 2017 5:43pm |
OK great will have a look around.
quick look on ebay found one for £220 will continue searching |
12th Feb 2017 5:50pm |
Maris Widgeon Member Since: 11 Dec 2013 Location: Cotswolds Posts: 216 |
Changed the tyres on my series to 7.50s and I think that it drives better as it gears it up a little ,so the engine isn't having to rev so hard to reach "50mph" , which makes it a more relaxed drive.
As for the speedo it makes it almost spot on with the GPS. That's when the needle is readable and not fluctuating over about 20mph . Radials also make for a nicer ride , you can always pop the 6.00 back on from time to time , nice little truck . Nick |
12th Feb 2017 10:13pm |
PCA42 Member Since: 15 Jun 2014 Location: Church Stretton Posts: 468 |
Those should smarten it up and make it more driveable I'd probably have them powdercoated in Limestone myself for a more classic look, but since the white is so good probably not worth it.
I'd keep hold of the 6.00s and original wheels for originalitys sake. On my 88", the speedo under reads by 5mph. Fine if you remember, I do, just one of those jobs I've just not got round to as I need to find the correct Series III type but without the trip meter from a later one. I found one but it had the wrong speedo cable connector on the back so the job got put to the backburner again Pete 2010 Discovery 4 GS TDV6 1972 Series III 88" 2.25P |
13th Feb 2017 11:15pm |
RoddyK05 Member Since: 08 Apr 2015 Location: Inverclyde Posts: 633 |
Mine showed 25mph whilst I was sitting at 30. I put up with this for years before I picked up an old 109 to source bits from. The gearbox was a recon unit with O/D fitted so it was out of the 109 and into my 88 with it. The speedo head was also changed over and this gave me a reliable measurement of my road speed. It made very little difference to me but was one of those wee jobs that I had been meaning to get round to. Back then you could get old series motors for next to nothing as there were loads lying about that were rusted or hadn't turned a wheel in donkeys years. Still see the odd one sitting about, but mainly just a pile of rust on four wheels now a days. Old style garages usually had an old series wrecker sitting about somewhere, nostalgia - can't beat it. I'm sure I still have the old SWB rims knocking about, no idea what I'd do with them now, probably fit for scrap.
13th Feb 2017 11:48pm |
Will the bolts off the old wheels fit these ones?
Thanks |
15th Feb 2017 7:03pm |
