Home > Technical > cheapest way to get memory maps up and running ?
Page 2 of 2 <12
landy andy
I run MM on my laptop via a 8" screen , but also have the Memory Map Adventurer 3500 GB. This is the best way to use MM if you do not want to run computer. They are available from Devon 4X4 for £320, but got mine at Cotswold for £260. As mentioned before you can also use the Memory Map Adventurer 2800, but the screen is very small, and these are availble from Devon 4X4 at £245, but again can be got from others cheaper. These also come with discs for your home PC should they be required.
All the MM devices should be the GB versions which come with all the UK maps. You can buy the sections should you wish, but will cost you more in the long run.
Andy
Post #54876 24th Jan 2011 9:52pm
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
thanks again guys. Thumbs Up
Post #55005 25th Jan 2011 8:13pm
fekete
This will be the cheapest way
http://www.mynewsletterbuilder.com/email/newsletter/1410154891 NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #55172 26th Jan 2011 6:40pm
mse
Hows that different to the memory map apps you get now for free or £19.99?? Mike
Post #55185 26th Jan 2011 7:01pm
double cab happy
just need the i phone and that would work a treat Laughing
memory map gps or satmap me thinks.
Post #55227 26th Jan 2011 9:59pm
BigMike
can't fault the satmap. I find with an iphone 3GS that the GPS is very unreliable. it gets confused between cell towers and actual gps and sometimes is way way out. its not reliable at all. satmap on the other hand is pinpoint accurate at all times and the route recording function is easy to use, easy to save and store the routes. if you get a satmap, get the suction cup mount to, its very reliable. I've been experimenting with an iPad and whilst the screen is fantastic, its a big bit of kit to have in the front if you're bouncing around.
Post #55233 26th Jan 2011 10:32pm
double cab happy
thanks again guys, hints to my better half for my birthday then,
cheers
mark
Post #55264 27th Jan 2011 9:52am
BigMike
Here, a good video on the iphone (contains swearing) Laughing
Post #55502 28th Jan 2011 3:23pm
Page 2 of 2 <12
