Home > Technical > Tdci Doors onto a Tdi |
I'm sure the defender size door has not changed since series 3? So I'm sure it will be fine. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
23rd Jan 2017 2:49pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4785 |
Yes, direct swap 2002 90 Td5 Station Wagon
23rd Jan 2017 3:19pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2224 |
Since series 2 😉 The Land Rover 90 - Many are called, few are chosen.
50 Shades of Pennine Grey |
23rd Jan 2017 5:01pm |
Cheers Mo, knew it was one of them 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
23rd Jan 2017 5:10pm |
chrispy Member Since: 13 Mar 2015 Location: Gwent Posts: 347 |
Thank you. What else would be needed to get the electric windows to work? My wifes 90 has a Td5 wiring loom in it and i'd like to make this as effortless (and inexpensive) as I can. I've seen kits online to add electric motors to the windows but if I could utilise the ones on the Tdci doors i'm looking at all the better.
Thanks for all your help chaps, this place is amazing for knowledge, help and also encouragement. Others just say not to bother but here it seems to be f*** yeah...go for it! |
23rd Jan 2017 5:34pm |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1749 |
You can do it.
I did the same. Bought a Td5 bulkhead loom that supported electric windows and central locking. I then extracted the relevant wiring and then grafted it into the existing loom, utilising the same routes and plugs. The central locking was easy as the wires are pink or orange and they just got soldered into existing ones from the alarm ecu. The alarm ecu needs changing if you don't have central locking already. They can be modified, but if you search for the right one they do come up on ebay. So by doing the wiring pretty much as LR did it - if an issue occurs then any help on usual remedies from people on here will be of use rather than a 'Well it could be any one of many things....' !!! Happy to answer any further questions on this |
23rd Jan 2017 5:55pm |
foxyred Member Since: 16 Jul 2016 Location: Nottingham Posts: 227 |
You don't need a special loom for electric windows, Power from battery to fuse, then to carling switch per window then to electric window motors.
You Do Not need a relay dead easy. Central locking is different kettle of fish Alarm fitter wired mine |
23rd Jan 2017 8:00pm |
Thanks guys, much appreciated
23rd Jan 2017 9:05pm |
psimpson7 Member Since: 20 Nov 2013 Location: Gold Coast, Qld. Posts: 221 |
On another note, I would also want to be certain that the doors that were for sale had a genuine reason for being on sale and weren't removed from one of the numerous stolen Defenders that are mentioned here on a weekly basis. 2001 90 HT 6.0LS/6spdAuto.
2003 90 td5 soft top. 2014 90 XS SW 2.2. |
23rd Jan 2017 9:21pm |
Gurmot Member Since: 01 Apr 2016 Location: Somerset Posts: 36 |
I would also be checking they weren't stolen. A pox on anyone who sells stolen defender parts
23rd Jan 2017 9:33pm |
It was rear ended and an insurance write off. I'd never buy anything Land Rover without checking it's genuine and not stolen first.
24th Jan 2017 6:04am |
