Home > Stolen > Spotted today abandoned on a lane in wales |
Bows Member Since: 07 May 2012 Location: Wales Posts: 516 |
Possibly just stuck, and owner had to leave it there to arrange recovery, 2006 TD5110 station wagon
1995 300Tdi 90 truck cab 1989 90 hard top with 200 tdi 1983 110 hard top 1983 110 Hi cap 1954 107 pick up |
15th Jan 2017 11:39pm |
defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1629 |
It has a winch !!!
16th Jan 2017 9:44am |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
...and no trees to winch it out, and probably too wet to use a ground anchor SKIP
https://www.defender2.net/forum/topic83242.html |
16th Jan 2017 9:46am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17544 |
It has an illegal front number plate too.
When night falls it will be parked on an unlight right-of-way after the hours of darkness without lights. Shocking, definitely should be reported. Hopefully by now the owner will have found a grown-up to help to recover it. |
16th Jan 2017 10:02am |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Classic case of "all the gear no idea" 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered. |
16th Jan 2017 10:10am |
Not quite all the gear...Assume also there was no second Vehicle with this outing...
SKIP https://www.defender2.net/forum/topic83242.html |
16th Jan 2017 10:21am |
Yes "it has a winch!!!" but as previously mentioned, doesn't look like there's anything to winch off. It appears to be a good example of why you shouldn't go greenlaning alone. 2006 TD5110 station wagon
16th Jan 2017 10:25am |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 |
poor . The reason I never go alone 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r |
amondeggs Member Since: 06 Mar 2011 Location: Telford Posts: 452 |
There were no trees your all correct.
It was odd that the car had been left unlocked too??? As said I reported to police but they did not tell me if it was recorded as stolen or not. |
16th Jan 2017 11:32am |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2954 |
Maybe thats because YOURE NOT THE POLICE
16th Jan 2017 12:07pm |
stolen and abandon then stuck
16th Jan 2017 12:10pm |
Pull Pal ground anchor for use in soft ground conditions or as others have said don't go alone. Of course if its been nicked.......
16th Jan 2017 1:03pm |
I wonder if they had a spade or shovel (the first piece of recovery equipment you should carry) with them.
You'd have that out in no time with a spade! |
16th Jan 2017 4:34pm |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1364 |
Nothing to say he hasn't snapped a prop or a diff has broke
16th Jan 2017 4:40pm |
