- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
taazzukcb
[Wanted] TD5 Engine Harness | |
Hi all,
After the engine loom for a TD5. The one with the Red ECU plug on.
Defender preferred as I may be able to utilise other bits, but disco will do as I need the big grey connector from it mainly at the moment!
Also a window rocker would be good as it seems on of mine had been broken.
Thanks .
12th Jan 2017 10:29pm |
