Home > In Car Electronics > Cable guide
mse
Cable guide
Can you help/check this
I have loads of 16 - 30 amp thinwall automotive cable, that i usually use - but i needed some 2 core cable (red black) to finish wiring some fixed LEDs
LED draw for the complete run is 24w @ 12v so 2 amps - but they are cut down and split into 2 pairs.
The question - i ordered some cable (next day job not my usual - lucky if you get it in a week - supplier). Whats come wasnt what i expected, but i cant remember enough to decipher - so it this wire ok? on it it says 0.5mm2 (x2C)Seki Speaker Cable
Its supposed to be 6amp
I think it is but i wanted to check
Thanks Thumbs Up Mike
Post #590701 6th Jan 2017 2:05pm
miker
2A down half mm cable will be absolutely fine.
Post #590712 6th Jan 2017 2:23pm
mse
Post #590721 6th Jan 2017 2:44pm
Martin
Site Admin
Agreed  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #590722 6th Jan 2017 2:53pm
dorsetsmith
Post #590747 6th Jan 2017 4:38pm
mse
Thanks - when i compared the gauge of the wire and the one supplied when i was soldering it was obviously better - just totally not the type i ordered, but its in and seems ok.
Thanks for reassuring me Mike
Post #590803 6th Jan 2017 7:07pm
