Home > Maintenance & Modifications > Suspension upgrade and tyre size
Bart 82
Australia
I want to upgrade my suspension for a smoother ride on the road ie small bump smoothness . However I do go away 4x4 and camping expedition stuff what do people suggest. I also don't want to change my wheels but was thinking of putting some 30 mm spacers on.
Post #589361 2nd Jan 2017 7:31am
grafty99
I have triple rate progressive springs from IRB developments on my 90. The first inch or so of travel is softer than standard the second part is the same as standard then the last part of the spring is harder than standard. These paired with bilstien dampers makes for a really compliant and controlled ride Thumbs Up
Unloaded the suspension is really supple and with a load or towing it doesn't sag excessively and is still comfortable.
I used to run wheel spacers before I changed my wheels, I was never keen on them because you are doubling the number of wheel nuts that could become loose and you are increasing unsprung weight which is detrimental to ride quality. The dampers have a harder time controlling the axles. I'm sure that I read somewhere that rotational unsprung mass is the equivalent to 5 or 8 times the same weight as static unsprung mass.
Wheel spacers definitely improve the look and steering lock though Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #589379 2nd Jan 2017 9:14am
Blackhat90
Scotland 1995 Defender 90 300 Tdi HT Epsom Green
Aye Grafty " do you have a link for the triple rate springs ,?. sounds good Rolling Eyes
Post #589572 2nd Jan 2017 8:50pm
