Home > 130 > Demountable on 130
Page 2 of 2 <12
photoguy
Trundlebus wrote:
I have had my bimobile 130 for nearly 3 years and driven over 20000 miles around europe in it. it is set up correctlly with upgraded, springs,shocks roll bar and air bags as i described.
Hi Trundlebus,
I'm just about to get a 130 to fit my S. Karosser demountable on could you give detailed specs of the springs, shocks, roll bar and air bags that you use and where you purchased from?
Thanks!
Post #705732 7th May 2018 8:11am
Trundlebus
Hi,
bit of a problem there, it was all taken care of by Darren from Adventure overland.
I will let him know that you were asking and ask him to reply directly.
I do know that we have an uprated rear anti roll bar and dampers and that the inner rear suspension springs were removed and airlift suspension bags put in. These work well but I ignore the 35ilds pressure limit and take them to 50 psi when loaded.
the air suspension was Airlift UK http://air-lift.co.uk/.
Don't know what your demaountabe wieghs but we go up to 3500KG when fully loaded and have been re-plated accordingly.
Post #705746 7th May 2018 9:05am
What wheelbase is this?
http://demountablecampergroup.com/viewtopi...608#p15608
Post #873319 16th Dec 2020 7:05pm
If it's based on something that LR produced then it could be a 147". If it's a one-off build then it could be anything. Darren
Post #873334 16th Dec 2020 8:08pm
Page 2 of 2 <12
