![]() | Home > Td5 > Need help - metal jingle/rattle noise (sound recording) |
jrharte Member Since: 08 May 2016 Location: Newry Posts: 20 ![]() ![]() ![]() |
Hey guys,
I've got a 2000 TD5, I actually bought it from a guy on here (RFDemon) earlier in the year. It's been a dream to drive but I'm recently noticing some noises that shouldn't be there ![]() Booked in with my mechanic for tomorrow but in the meantime I had a quick look through forums for an answer. Most threads point to universal joint or a frame ball joint. You can hear the noises here: https://youtu.be/jUNLyTM4ibA The loud squeak is the spring on the clutch pedal. There is also a loud single clunk noise from the back that happens randomly when pulling off or letting off the accelerator. It doesn't happen every time though. I didn't get it in the recording. |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5919 ![]() ![]() ![]() |
My engine squeak was the turbo heat shield - the rivets had worn through at the back and the shield was rubbing and squeaking 1999 Defender TD5 110
