Home > Maintenance & Modifications > county interior |
Morepower Member Since: 08 Jan 2013 Location: Fife, Scotland Posts: 630 |
The std puma 90HT even in XS Spec like mine has nothing in the back... (well apart from a black headlining)... I had to spec a rear load mat and the sides had nothing, Although I did get some speaker mounts in the corners... The 110 USW on the other hand had rear window surrounds and side covers.. (although I had to buy some TGE inserts)... although again I had to add a load cover in the back...
Hope that helps.. Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
14th Dec 2016 7:51pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5208 |
cheers, what models had the full spec in the back?
14th Dec 2016 8:34pm |
Riverboy Member Since: 16 May 2016 Location: French sector, Earth Posts: 1288 |
My 90 SW as it was when I first saw it and as it left the factory. It seemed to have it all really. Head lining, side linings, carpet, rear seats etc etc. Its an export model so I have no idea if they were different to UK models. I don't know what they call the county spec over here
Click image to enlarge |
14th Dec 2016 8:43pm |
That's what I want to have! Is there a full blown kit for kitting out a landy, I know the seats you can buy, Its the interior trims and carpets I am after.
14th Dec 2016 9:05pm |
you can buy the carpet for the rear... I bought it for the 110 from landrover and made my own sides
14th Dec 2016 9:14pm |
I think simmonites do a copy rear plastics kit for window surrounds etc and a full roof lining would probably brighten it up a bit which you can get on eBay or maybe Lri solutions (site sponsor) Ray
14th Dec 2016 9:36pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2658 |
There are no factory trims for the rear sides of 90 hard tops, they were all bare. Station wagons had trims, but also windows/seats/carpets etc.
I have used a set of 90 SW rear trims to fit out the back of my 90 HT. Click image to enlarge The rest is just carpets/headlining, fairly simple. |
14th Dec 2016 9:45pm |
I like that! How much did that set you back?
15th Dec 2016 4:03pm |
The trims were c. £150 - they go for silly money second hand. Headlinings were a few quid from local breakers.
Carpet etc. was cheap from one of the big carpet shops. Got the end of a roll. |
16th Dec 2016 9:30am |
I will be looking at kitting mine out with in a decent budget, What place is the best of headlining? I have speakers in mine, so I want to keep them there, I am not faffing on moving wires and drilling dashes.
16th Dec 2016 7:38pm |
VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512 |
La Salle Trim does headlinings and trim. I do not have personal experience with them, but it seems good quality... Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
16th Dec 2016 8:07pm |
RichLech Member Since: 09 Nov 2015 Location: West Sussex Posts: 115 |
These side panels are a great fit, help stop drumming noise and protect the thin aluminium sides.
http://www.mudstuff.co.uk/mud-90-side-panels.html |
16th Dec 2016 8:25pm |
only thing with the headlining is I have speakers up there, I have seen one which looks like it has a radio slot built into it, I am just after a plain one like I have already, I am wanting to fit a roof console from mud at some point, just for the extra storage.
17th Dec 2016 6:10pm |
If you just have the front section of head lining you should be able to buy the rear section seperately and as I said simonnites do a rear plastic trim kit Ray
17th Dec 2016 8:29pm |
