Home > In Car Electronics > Any Double DIN installers recommended in the Surrey area? |
Nick-St Member Since: 23 Apr 2013 Location: Surrey Posts: 267 |
Looking to get a double DIN dash installed. The lazy side of me can't be bothered to do it if I can find a recommended installer in the Sussex / Surrey (Guildford-Kingston-Gatwick ish) area. Any suggestions?
14th Dec 2016 10:28am |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 |
Speak to Chris at CSK Landrovers 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
14th Dec 2016 11:35am |
Thanks for all the suggestions here & via PM. None of the installers suggested are very near, and if I have to spend a day going / waiting / coming back, then I may as well do it myself...
Just got to decide on which stereo to fit now... |
15th Dec 2016 11:21am |
pjb Member Since: 08 Apr 2009 Location: Sunny Oxford Posts: 1244 |
Hi have done it so its not particularly difficult
You make have to extend some of the switch cables - I had to extend 2 in the end as the cables were just too tight to get the unit back in comfortably. Just allow a day to fit it, as said is not difficult you just need to work methodically and keep everything tidy, and when putting back in try & run as many of the cables as possible away from the headunit as it is a tight fit behind the head unit. Good luck - there are some very good guides on here 2020 P300 HSE |
15th Dec 2016 12:17pm |
I figure I'll need to extend some of the cables as I've got to relocate 4 switches out of 6 that are wired as 2 pairs of 3...
I'm having more trouble finding a unit that I want to put in at the moment! I did think about the Alpine iLX-700, but not really sure how Apple maps / CarPlay behaves if you loose your 3G signal while navigating... (and it seems to have been out for a couple of years without being updated.) |
18th Dec 2016 8:35pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20583 |
There is a place in Herts that specialises in audio and does Defender installs.
I can't think of the name of it for the life of me though. Can anyone else think of it? I swear it's in the Herts / Essex area. (And no before anyone starts, I do not mean CSK. ) Or as suggested, there is the option of doing it yourself. Most info is online, but can be time consuming if you are very busy with other things. KEEP CALM AND Drill ON 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
18th Dec 2016 8:42pm |
I figured that if I could find a place that was recommended locally, then I'd let them do it - but otherwise if I have to spend a day travelling, then I may as well do it myself...
I haven't found my 'perfect' double DIN stereo yet though.. |
18th Dec 2016 8:51pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 |
Custom90Steve - is it Audio-file at Bishop Stortford you're thinking of? I believe Riverboy used them?
There is TMD Tuning at East Hoathly too. James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
18th Dec 2016 9:07pm |
^^^^ Yes, that's the one. KEEP CALM AND Drill ON
18th Dec 2016 11:48pm |
