Home > Maintenance & Modifications > Entreq front mudguard extensions
Page 2 of 4 <1234>
leeds
Lorryman100 wrote:
Damn......need to type quicker as leeds beat me to it Twisted Evil
SORRY! Laughing
Brendan
Post #53456 17th Jan 2011 4:52pm
Merlin
Thanks, great info. But as mine are rotating, How do I fix?
Merlin
Post #53463 17th Jan 2011 5:52pm
leeds
Merlin
Try following
Get a M6 Nut and bolt and two 10m spanners
Spin nut halfway up bolt.
Insert bolt into rivnut so nut touches rivnut.
Using both spanners, hold head of bolt still and turn the nut.
Effect should be to jack the bolt out and compress the rivnut onto the out rigger. Should only have to turn bolt a small amount to tighten the rivnut
See if that stops the rivnut spinning.
HTH
Brendan
Post #54136 20th Jan 2011 5:14pm
leeds wrote:
Merlin
Try following
HTH
Brendan
It works better if you put a washer between the nut and the rivnut before tightening.
Post #54138 20th Jan 2011 5:20pm
Merlin
Sounds good, but the bolts on the mudflaps are rotating so I can't get the mudflap off so I can get the problem sorted. The mudflap is banging about so needs tightening before it disapears.
Merliln
Post #54149 20th Jan 2011 6:44pm
leeds
Try prising the bolt head down with say a screwdriver/pry bar putting pressure on the rivnut, then you might be able to undo bolt.
Hope that makes sense.
Good luck.
Brendan
Post #54157 20th Jan 2011 7:24pm
Lorryman100
A little feedback on the performance of these extensions. Run the Landy this week without the need to wash it Thumbs Up The guards stop about 80% of the muck that used to obscure the drivers window and door mirror, the sides of the Landy are also a lot cleaner meaning I stay clean getting in and out of it Thumbs Up On the whole I am glad I fitted them, once the rock sliders are fitted they should help some more as the brackets where designed with rock sliders fitted, but work almost as well without them.
It's mostly the bottom of the snorkel and a little of the drivers door.
The drivers window and mirror are now clean
Some spatter on the rear door.
When you have left lock on you still get some spatter but no where near as much as I used to get Thumbs Up
Post #54694 23rd Jan 2011 7:03pm
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
Who shattered your passenger window Confused
Post #54695 23rd Jan 2011 7:15pm
Lorryman100
Nobody, it's my neighbours rough cast Whistle
Post #54701 23rd Jan 2011 7:47pm
K9F
I ordered a set of Entreq mud guard extension brackets on the 3rd February and received confirmation of payment, an order number together with a status of 'processing' against the order! Great I thought!
Since then NOTHING???? Despite an e-mail to Olaf requesting an update on Saturday!
Impressed?? Not very!!! At the moment anyway! Big Cry
Lorryman any details how long you waited would be very welcome about now! Thanks Buddy! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #59296 15th Feb 2011 10:21pm
Lorryman100
Ordered on Wed 5th Jan, and was delivered Tue 11th Jan Thumbs Up
Post #59302 15th Feb 2011 10:36pm
K9F
Thanks Lorryman, will wait another couple of days before gnawing on my cot side and throwing teddy about a bit! Whistle If you go through life with your head in the sand....all people will see is an ar5e!!
Post #59312 15th Feb 2011 11:49pm
K9F
**Update** Received the following e-mail today...
Hi Malcolm,
Your mudflap extensions have been sent yesterday with parcel service.
The next 50 pairs of mudflap extensions will have an upgrade. I will sent you the additional U-profile for free……………this is easy to change and you do not need to use screws any more.
Thumbs Up So everything appears rosy again and teddy can sleep safe in the knowledge he's not getting hurled about just yet!! Very Happy If you go through life with your head in the sand....all people will see is an ar5e!!
Post #59630 17th Feb 2011 3:55pm
TC
I am going to try this approach before extending the arches. The guys in Canada still haven't gotten back to me over shipping two sets of Fekete's extensions back to the UK Rolling Eyes
Post #59632 17th Feb 2011 4:00pm
K9F
Entreq extension brackets for mud flaps have finally arrived! Must say at a glance they appear well engineered with all stainless fixtures and fittings! Thumbs Up
May even spend a few hours polishing them up for extra bling factor! Cool If you go through life with your head in the sand....all people will see is an ar5e!!
Post #60777 23rd Feb 2011 5:09pm
Page 2 of 4 <1234>
