jdci2001lu
Speedometer failure when cold | |
Hi,
I just fitted the terrafirma cruise control to my 2013 SW puma.
The issue is :
below zero outdoor temperature , it takes about 4-5 km till my speedometer is working.
I did crimp the feed to the speedometer to the cruise control.
If I start driving right from the garage ( where the temperature is about 16 degress ), it works fine , just from the start.
Any suggestions ?
Thanks in advance.
5th Dec 2016 1:43pm |
jdci2001lu
The solution to the problem :
bad crimping to speed signal
solved and now
4th Jan 2017 5:58pm |
