![]() | Home > Spotted > What was that then? |
BBSJK Member Since: 12 Sep 2009 Location: Ledbury, Herefs Posts: 100 ![]() ![]() ![]() |
Sat in a queue on the way home from work today (in the Citreon
![]() I usually tell by the simple bonnet bulge but it had its back to me. So how many seats in the back? It was dark so that was a no go ![]() That has brought me to a (very sad) question. How can you tell the difference between a Puma and the older Landy's? 1) Bonnet Buldge 2) Seats sidways in older one and forward facing in the puma 3) fake vents in the front (but I guess you'd have noticed the bonnet by then!) 4) Any more ? JK No the other left . . . |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
By the Defender badge on the rear off side. The Puma's badge is onderlined. Others aren't i think.
By the rustiness of the rear x member! By the four plates with two bolts in each that connect the rear x member to the body - on the Puma they're on the outside, others the inside or vida versa? Can't remember, it's Friday, i'm on my second bottle of Cotes du Rhone! By the bulge of the vents on the dash if you can catch a glance inside. By the number of rivets on each side - Puma 17, Td5 16. (Joking ![]() |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
Changed to the inside with Td5 and same on Puma. Went from outside on the Tdi. type the reg into the DVLA database ![]() Glyn ![]() |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 ![]() ![]() ![]() |
If moving at the time of the spot open your window and listen, if its a Puma you will hear the wining of the diff.
If stationary at lights etc, if its Puma you will hear the clutch rattling. 130's have feeling's as well you know ![]() |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
Andrew have you got anywhere with the engine tune yet .
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 ![]() ![]() ![]() |
No Chap Been very busy at work so not had chance to get J-Lo back to the dealers. 130's have feeling's as well you know ![]() |
MrFlips Member Since: 27 May 2009 Location: Cardiff Posts: 682 ![]() ![]() ![]() |
No, I'm guessing fake air vents under the windscreen - the one thing I really miss! Peter 2008 SWB Truck Cab 1952 80" Soft top |
I was thinking of the fake vents under the windscreen. I was expecting the miss those but I can't really sy that I do.
I guess the Puma would be the one of the AA recovery truck then? I played 'spot the difference' when I first got the puma with my 1986 90 and found the mirrors even had the same serial number of them! JK No the other left . . . |
They are not fake vents under the screen. I think I was told that the two embossed rectangular panels are there to retain strength in the bulk head. 130's have feeling's as well you know
shazzy90 Member Since: 17 Dec 2010 Location: tyneside Posts: 489 ![]() |
the only way to spot the differance between all models tdi,td5 tdci is to check the tax disc if it is not a commercial,a tdci will pay £400 plus atdi and td5 will pay £220
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5805 ![]() ![]() |
If you are that close you can look through the window, and see the difference.
The difference behind Tdi to Td5 are easy from behind due to the exhaust change, and even the fog/reverse light lights are an indicator (but later Tdi's also had the round ones) But the difference Td5 to Tdci from behind...................... No can't think of any Andy |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5068 ![]() ![]() ![]() |
Rectangle Red Reflectors on the rear.
Generally the people going slowly looking in pain in the TD5...TDCI happy people getting somewhere in warmth silence and comfort ![]() ![]() ![]() |
