![]() | Home > Maintenance & Modifications > Replacement radio aerial |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 ![]() ![]() |
As per usuall Halfords baby fitters not knowing anything, yes you can get loads of combined dab fm amplified aerials, mine is mounted above the interior light easy to drill and run the cables down the l/h a pillar, it looks like a hatch back aerial flexes into car parks ok, got mine on the net its made by Blaupunkt, they also do stick on ones for inside the window telescopic ones etc etc. If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
Great, thanks mate.
Nice to know that combined DAB/FM aerials are available. I might have to mount on the roof as you have. Was only considering putting it above the tailgate door so that I could spot any leaks around it. Cheers ![]() |
