Home > Technical > Vent Flaps Leaking
Skelkelly
United Arab Emirates
Vent Flaps Leaking
Hi All
Looks like my damp feet are caused by the vent flaps letting in water.
Anyone managed to stop theirs leaking?
Ta
Shaun
Post #577110 11th Nov 2016 1:09pm
alpacaman
New seals?
Post #577114 11th Nov 2016 1:19pm
Skelkelly
That was my first thought but just wondering if anyone had any other tips as I notice the flaps themselves aren't particularly well lined up. I.e. one corner sticks out further than the rest.
Post #577116 11th Nov 2016 1:23pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
Yes I bought a Puma...... I'll get me coat Smile
Post #577157 11th Nov 2016 5:13pm
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
New seals, patienc,e and a better adhesive.
The Puma option is well worth considering, but on a summer day, the open vents are an old school luxury. Laughing it's a Landrover thing...
my renovation thread:
http://www.defender2.net/forum/topic40792.html
Post #577173 11th Nov 2016 6:42pm
Screbble
Re: Vent Flaps Leaking
Skelkelly wrote:
Hi All
Ta
Shaun
Are you certain it's the flaps?
If so, it should be easy enough to sort with new seals etc. If I were you I'd whip them off and inspect them if they are out of alignment - maybe square them up on the bench and fit new pins.
Plenty of other areas around there that could give you the impression it's the flaps.....
Faux hinges, horizontal seal between windscreen frame and bulkhead, tracking from gutter above door.....
Whatever it is I hope it's a quick, inexpensive fix Thumbs Up
Post #577180 11th Nov 2016 7:40pm
Screbble
PS read somewhere on here that there's quite a difference between the foam and the rubber seals so it's worth doing a search Thumbs Up
Post #577182 11th Nov 2016 7:41pm
dorsetsmith
land rover water ingress manual
https://1drv.ms/b/s!AtZSoWFHDgnGhERwdB-0XcdTS_UI
https://1drv.ms/b/s!AtZSoWFHDgnGhEXR_LnW7L0tyDit
Post #577183 11th Nov 2016 7:42pm
CDN38
To check the integrity of the bulkhead (other than the vent seals) , I taped the entire surround of the flap carefully with masking tape (bridging the gap between the bulkhead and flap it's self) then sprayed the hose on the area for about 10 minutes to see if there was any leaking of not. It's not 100%, as the relative wind of driving can push the water through, but if there are other leaks, they will show themselves. That means it's not the vents.
The water ingress manual is good to go by... it's a Landrover thing...
Post #577187 11th Nov 2016 7:49pm
Skelkelly
Thanks for the replies, the tape and hose idea is a good place to start by the sound of things
Let's hope it's a dry winter!
Post #577254 12th Nov 2016 9:14am
Skelkelly
The water is dripping off the door stay if that gives any clues?
Post #577256 12th Nov 2016 9:16am
dorsetsmith
have look at the water ingress manual links
Post #577260 12th Nov 2016 9:23am
